I am defeated and I give up
  • Flying Scotsman
    Fast Electric Adict!
    • Jun 2007
    • 5190
    With all due respect to Fluid the Toysport Triton as sold by OFE is not a true step hull design, it does have a VERY minor one step. But all said and done CG, rudder depth and rudder position are really important. Also what servo and rod diameter? As i noticed your hull turned better to the left!
    Tom that is a hoot, but I noticed you had the prescense of mind to remove the good stuff first
    Douggie
    • Jedi Master
      • May 2008
      • 242
      Originally posted by H&MWill
      Sounds good guys. Thanks Ill try out some more stuff this weekend. Will
      What rpm are you reaching and what prop do you run? I have a Triton without the step, direct from Joseph. Mine runs 45,000rpm with a 48mm steel prop. Hits 60mph, has never spun out and runs as straight as line. And to change the handling I just move the weight forwards or back. If I want to sport run at 35-45mph I pull the weight back to lift the nose and run on the tail. Above 50mph I push all the weight up front, which makes it run very wet at low speed but once its over 50 it levels out great. As mines fitted with a flood chamber, I run the weight to the left too, which makes no difference to the handling once its on the plane. I have been told that moving the weight to the left (even if you don't have a flood chamber) helps to counter-act the prop walk.
      Let us all know how you get on.
      Do or do not, there is no try!!!!!
      Aeromarine Titan 29 H&M Hawaii Kai III Proboat Stiletto ML Boatworks PS295 (No.8)
      • Flying Scotsman
        • Jun 2007
        • 5190
        Jedi, if you look very carefully there is a step.
        Edit: some of your figures make no sense
        Douggie
        • Eyekandyboats
          • 1921
          yes flying is right. the Triton is not a stepped hull. BUT it is classified as a stepped hull because the stakes end at a right angle. the ride pad of the boat is one complete. it has a good large flat ride pad to it which is what might be causing your poor handling.
          EYEKANDYGRAPHICS
          www.rclipos.com
          • Doug Smock
            Moderator
            • 5272
            Taylor, there is a stepped and non stepped version.
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • Eyekandyboats
              • 1921
              here is the bottom of mine. i am not aware of two versions of the Triton. other then the flood chamber and non flood chamber
              EYEKANDYGRAPHICS
              www.rclipos.com
              • Flying Scotsman
                • Jun 2007
                • 5190
                I did not know that but Will apparently bought the OSE model.
                PS how are you doing
                Douggie
                • H&MWill
                  • 623
                  #23
                  Bottom
                  Hey guys thanks for all your help. Here are some pics of the bottom. Will
                  Many issues!!!
                  • Eyekandyboats
                    • 1921
                    #24
                    ahh!!!.
                    interesting.
                    doing good doug. building 3 boats at the moment and have plans for another when it comes in the mail
                    EYEKANDYGRAPHICS
                    www.rclipos.com
                      #25
                      With all due respect to Fluid...
                      Respect accepted.
                      • H&MWill
                        • 623
                        #26
                        Tom, by the way I cant explain how many times I have wanted to stomp somethin like that but I didnt think someone actually would! LOL.
                        Many issues!!!
                        • G Doggett
                          • 446
                          #27
                          Sorry to hear your Triton is still giving you grief.
                          Maybe I'm going back over old ground here, but are you absolutely sure that the rudder or rudder servo are not causing this ?
                          The way it violently spins to the right while in a straight line looks like a major glitch could be making the rudder suddenly turn.
                          As Jay has said, the rudder is all that keeps the boat from following the prop walk on any boat, possibly more so on a stepped design.
                          On a hydro at full speed there is no hull in the water at all at the rear so all that keeps it straight is the rudder.
                          Graham.
                          Fellow Triton Owner.
                          • SJFE
                            • 4735
                            #28
                            Will I have to agree with the guy's in regard to the rudder. Pick up the Speedmaster 5.25 wedge rudder from the store and mout it nice and deep. See what you come up with.
                            Yes Douggie I had presents of mind to remove the vitals before total destruction. There are moments if clarity in even the darkest depths of insanity
                            • Flying Scotsman
                              • Jun 2007
                              • 5190
                              #29
                              Originally posted by Fluid
                              Respect accepted.
                              Thanks Fluid
                              My Triton is the same as EyeKandy and I was not aware of the Triton with a step as shown by H&MWill. I will now go and stand in the corner until Jay tells me I can play with my boats again.
                              Douggie
                              • Jedi Master
                                • May 2008
                                • 242
                                #30
                                Douggie
                                My Lehner 2240/7 runs at 45,000rpm
                                The prop is a steel, balanced 48mm.
                                The boat will hit speeds of 60mph.
                                Basically I'm saying that I run mine faster nad harder than the design spec, and suffer no handling problems.
