Spark arrester.
  • mappo
    • Feb 2010
    • 488
    Spark arrester.
    Hi is anyone using a spark arrester on the New castle hydra ice? i am looking to put a 2028 in my 57" p1 venom using 10s, and knowing what i get with 6s i can imagine what 40+ volts will do sparkwise!
    Any suggestions will be gladly accepted. thanks..
    Do you know what the biggest problem with the world is?
    That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
  • Gary
    • Jan 2009
    • 1105
    Wow thats a lot of voltage!! Be carefull with it!!
    H&M 1/8 Miss Bud 73 mph
    Chris Craft 16 mph
    • iridebikes247
      • Dec 2011
      • 1449
      I am assuming you will be running 10sp? If so this thing is pretty cool...
      I run 11s1p per side in my boat and I use this
      It has a neat setup and you will not get a spark if you use it correctly. Sometimes you'll get a really really small one like connecting a 2s pack but I'm pretty sure you're HV castle esc won't complain about it. Kintec sells a spark arrestor setup but I like minimizing how much wire floats around in my hull. Your boat should rip with the 2028!
      • MrUnlimited
        • Jan 2011
        • 94
        Can you show me a picture how you soldered that? I assum you soldered the 2 red wires to the left connector and the 2 black wires to the other connector?
        • iridebikes247
          • Dec 2011
          • 1449
          You have the castle 200 hydra ice, just tun the wires and then add some solder to the board. It takes a lot of heat to solder big wires to the board so in this order
          1. tin the board
          2. tin the wire and get it really hot
          3. put the wire onto the board and using the tip of the iron heat up the wire and board at the same time so the solder melts and thats it you'll have a good joint. it really really helps if you have another person hold the wire in place while you do this thats for sure
          • siberianhusky
            • Dec 2009
            • 2187
            Does Castle still reccomend NOT using an anti spark device? Was looking into installing them about a year ago and everything I read from Castle was not to use them.
            Do a search and you can find the info on many Castle sections of different forums.
            No idea just followed their suggestions and no problems so far.
