Hi GuysI help again
My last threads re the conquest has really helped me but I was out earlier and only managed98 km/h as I could not open throttle up as boat is too unstable. THE BOAT wags its tail left back down then right down as well as porposing.I think this is called chiming. I listened to Race Mechanix and Fluid and bought the speedmaster skegged strut and the boat is beter and does not turn to the right nearly as bad as it did but still the boat is very unstable at higher speeds
.Current setup
Conquest
2028 motor
300 amp esc
4 x 5000 mah 45-90 c batts 5 cell x 2 38 volt x 10000 mah
speedmaster strut with skeg 6 mm to right of boat centre.
Propshaft -between 10mm and 16 mm from bottom of sponson to middle of propshaft. 0 degree offset
CG Between 28 and 33 %
.Current setup
Conquest
2028 motor
300 amp esc
