Still too hot !!
  • bigmmmike
    • Oct 2011
    • 19
    Still too hot !!
    Got a new Tacon Brushless Motor LBP4074/2.5Y-2000KV & New Turnigy Marine 180A ESC still running hot Prop wrong ?
  • MAMBA2200
    I need a scooby snack
    • Jul 2012
    • 1202
    what prop what boat what voltage i run the same thing mine is the 2150kv mine runs cool all the time
    Im Only Responsible For What I Say Not For What You Understand
    • dana
      Banned
      • Mar 2010
      • 3573
      What boat? What prop? What timing? What batteries?
      • MAMBA2200
        • Jul 2012
        • 1202
        good call dana lol
        • dana
          Banned
          • Mar 2010
          • 3573
          Oh and what is "hot"? 140 degrees?
          • lenny
            • Sep 2010
            • 4294
            Pictures of the setup,
            And video of boat running in a straight line would be good to.
            ? ONLY IF THEY WORK
              In July the OP's problem was - apparently - a shorted ESC in his Apparition which caused things to get hot by the time he finished taping up. Is this still the problem, or is the boat running now and thermals off?
              • bigmmmike
                • Oct 2011
                • 19
                Yes Fluid ESC heats up while Taping to the point of no go when its tossed into my Lake
                • dana
                  Banned
                  • Mar 2010
                  • 3573
                  Why would you not replace the esc?
                  • bigmmmike
                    • Oct 2011
                    • 19
                    I did ... got a new one doing the same thing so hot smells and cannot touch
                    • dana
                      Banned
                      • Mar 2010
                      • 3573
                      My bad you did say its new. So something must be plugged on backwards?
                      • lenny
                        • Sep 2010
                        • 4294
                        Like I said pictures,
                        Of setup and what part of the esc is getting hot.
                        And how hot with temp probe.
                        ? ONLY IF THEY WORK
                        • madmikepags
                          • Aug 2012
                          • 1359
                          you using a reciever pack or bec? if the esc has a bec and you're using a rec pack without unplugging the red wire on the esc this will heat the controller up. also make sure the neutral position is set correctly.
                          We call ourselves the "Q"
