Electronics Problem?????????
  • rabosi
    • Aug 2011
    • 200
    The problem you described seems like the well documented Seaking LVC issue. You can try lowering the lvc in increments (eg 3.2, 3.0, 2.8...). Going to 2.8V worked in my case. If not you can try turning off completely as mentioned already. I've also noticed that better quality batteries seems to make a difference also (able to hold volts better under load).
    • dana
      Banned
      • Mar 2010
      • 3573
      How long has this been happening? What prop are you using? What is your strut depth? What is the cutoff set to? What batteries are you running?
      • dana
        Banned
        • Mar 2010
        • 3573
        I'm also curious as to why you aren't using a seperate pack for the bec? The seaking has built in bec, so why bother using the castle one if youre still powering bec with your packs?
        • MAMBA2200
          I need a scooby snack
          • Jul 2012
          • 1202
          cause it drops my amp draw between 7-10 amps data by eagle tree
          Im Only Responsible For What I Say Not For What You Understand
          • MAMBA2200
            • Jul 2012
            • 1202
            the issue just started batts are 5000mah 40c shy lipo strut is dead level cuttoff is set to 3.4
            • dana
              Banned
              • Mar 2010
              • 3573
              Turn your cutoff down to 3. 3.4 is high for that esc. Ok I can see why you use the bec now... 7-10 amps is pretty small tho. Try raising the strut up an 1/8
              • MAMBA2200
                • Jul 2012
                • 1202
                ok i will try to turn it down and then off thanks for all the help guysgreatest forum on the web
