Electronics Problem?????????
  • MAMBA2200
    I need a scooby snack
    • Jul 2012
    • 1202
    Ok guys i need help in a bad way i have 2 boats that are giving issues.I am running seaking speed controls in both boats one is a 120 and the other is a 180. When i first put them in the water and go to take off they blast out of the water and then seem to just go into safe mode. That is the best way i can describe it the seem to have full power for a split second and then only 3/4 power. I am using 2150 kv motors d wind and on my mystic i have blown 2 castle bec's in 2 runs. I have tried lowering timing making adjustments on my controler props and all i dont know what else to do please help.
    Im Only Responsible For What I Say Not For What You Understand
  • dana
    Banned
    • Mar 2010
    • 3573
    Did you disable bec on the seakings?
    • MAMBA2200
      • Jul 2012
      • 1202
      yes removed red wire
      • Jason4636
        • Jun 2012
        • 654
        And did you calibrate your throttle? Do you have the esc set to hard start? What do you have your lv cutout set at?
        • MAMBA2200
          • Jul 2012
          • 1202
          Yes calibrated lvc i have changed also using 40c packs no hard start
          Sent from my DROID RAZR using Tapatalk 2
          • MAMBA2200
            • Jul 2012
            • 1202
            And also im not getting high amp spikes eagle tree says around 105-110 amps
            • SirBudman32
              • Aug 2011
              • 625
              turn the lvc off and time your run. I've dont the same with the T-180
              Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
                • 7673
                Same with my 180 and my HV 80's.Had to turn the LVC "OFF".Then all was well. My 80's even went for a few runs before acting up.
                • ray schrauwen
                  • 9471
                  I just calibrate throttle and leave them on auto. Maybe a timing change but, thats it.
                  Nortavlag Bulc
                  • MAMBA2200
                    • Jul 2012
                    • 1202
                    I have done the timing change guess i will try the lvc and use a lvc alarm and do a short run and see what happens i guess what timing is best on a d wind motor???
                    • SirBudman32
                      • Aug 2011
                      • 625
                      I would start with 3.75 and go from there
                      • dana
                        Banned
                        • Mar 2010
                        • 3573
                        The bec should have nothing to do with the esc troubles no? The bec just powers your radio I thought.... I dont use external bec so I'm not really sure about that. As far as timing goes, should be no more than 5 degreees.
                        • dana
                          Banned
                          • Mar 2010
                          • 3573
                          Got any pics of the inside of your boat and setup?
                          • Jason4636
                            • Jun 2012
                            • 654
                            For d wind low timing, below 7.5. Y wind likes high timing, above 7.5
                            • MAMBA2200
                              • Jul 2012
                              • 1202
