Shock resistant epoxy?
  • stadiumyamaha
    • 1284
    Anyone know of a good shock resistant epoxy that is easily found.
    Adding a battery tray that will bridge the v in the bottom of a revolt. I'm afraid the standard 15 min epoxy will fail over time due to being to hard. The revolt hull is pretty thin and flexes a lot.
    white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
  • daveives
    • Jun 2009
    • 109
    G-force epoxy from West Marine or
    Permatex Ultra Blue Sensor Safe Silicone from your local auto parts store
    Gforce is formulated to be flexible and bond well - be sure to rough up the areas to be joined
    • madmikepags
      • Aug 2012
      • 1359
      use shoe goo strong as epoxy and flexible
      We call ourselves the "Q"
      • stadiumyamaha
        • 1284
        Cool. Thanks
        I going to go by a marine dealer tomorrow to see if I can find the marine tex.
        • stadiumyamaha
          • 1284
          Or the ones you mentioned. Thanks again.
          • properchopper
            rcgoatbuild@snotmail.com
            • 6968
            Very flexible bond and ultra strong Best sealant I've ever used (and I lived aboard a 40' wood boat for 15 years)
            • steinersamuel
              • Nov 2008
              • 405
              West System epoxy is one of the best on the market jason. If you have already used something, sorry for the delay, if not, i wouldnt use anything else! Bank on er!!
              • properchopper
                • 6968
                I agree that G-Flex is the best/strongest epoxy - I use it exclusively on all my builds BUT the OP asked for a FLEXIBLE bond - G-Flex cures rock hard, 3M 5200 is very flexible and will answer the requirements requested; " The Revolt hull is pretty thin and flexes a lot"
                • stadiumyamaha
                  • 1284
                  Thanks guys. I'm going to go to the marine dealer tomorrow to find it.
                  • properchopper
                    • 6968
                    Jay,
                    Here's a blob of 3M 5200 showing its flexibility (crappy vid but it does the trick) - And it makes a VERY STRONG bond - It does just what your after- I've used it in similar situations and it worked perfectly
                    • stadiumyamaha
                      • 1284
                      That is what I'm looking for. Any retailers sell it or is it mostly an online thing?
                      • capnswanny
                        • Feb 2012
                        • 817
                        I've seen 5200 at Wal Mart in the boat area here in WA. Was cheaper than West Marine. Ace Hardware might also carry it.
                        This is NOT a toy?!?
                        • properchopper
                          • 6968
                          West Marine stores, or likely any marine supply house. A little "googling" should help you locate it
                          • iamandrew
                            • 577
                            you could just use Poylester resin as well, it dosent set AS hard as west system, commonly used in full fibrelgass canoes to get a bit of flex
                            • stadiumyamaha
                              • 1284
                              Tony
                              Thanks for the info. I'm going to pick up some 5200 tomorrow at west. I didn't know we had one around here until you guys mentioned them. Happy thanksgiving.
