Where can I buy TP Power motors?
    • 9479
    Originally posted by jkr
    I suggest you better buy a leopard.
    Only the 6pol 56xx-58xx worth from them.
    not so...
    the 4060 4 pole motors are good
    and Steven was selling the 4050 with a T180 I think
    Hmm.
    If i were you and i had an esc that can handle 10s i would go for this:
    http://www.hobbyking.com/hobbyking/s...dProduct=19111
    Because of the 8mm shaft.
    Over 4082 you need 8mm shaft on the motor.
    5mm comes on the Leopard 4092
    8mm is not needed on a 40mm motor
      • 7990
      not so...the 4060 4 pole motors are good and Steven was selling the 4050 with a T180 I think.
      Nope, based on his testing Steve elected not to sell the TP motors (other than a few he had been sent as samples).
      5mm comes on the Leopard 4092...8mm is not needed on a 40mm motor
      Actually an 8mm shaft is badly needed on the longer motors like the 1527 - we saw 'way too much shaft whip in the old Neus with 5mm shafts. The internal shaft that is, it doesn't really matter what diameter it is turned down to on the PTO end.
        • 9479
        nope he came back and said they were good... reason he sold more
        and there are many who agree the TP POWER motors are good runners and run cooler than the same sized Leopards
        • carlcisneros
          • Jan 2010
          • 1218
          My TP Power 4092 1600KV running on 6s2p, x-447 de-tongued in my 39" Youngblood mono is running fantastic!!!!!!!!!!!!!
          actually pulls a couple of the faster gas monos in the area. (and they aint no slouches.)
          • 785boats
            Wet Track Racing
            • Nov 2008
            • 3169
            Yep. I run a couple of TP Power 4084 2180kv motors in a hydro & a mono. They outperform the Leopards of the same size in the same boats, on any day of the week ending in Y. They run cooler. The boat runs faster. And they use a bit less out of the packs doing it over a 5 lap race.
              • 9479
              my temps are down 40* and use about 15% less from my packs during a 6 lap race..
              • Basstronics
                • Jun 2008
                • 2303
                Maybe someone can tell me why the 3674 2400 kv sucks then?
                Im a bit disappointed in the performance...
                I hope the 4082 performs better as i have one to replace a 4074 leopard with.
                • jkr
                  FE Addiction
                  • 568
                  Their wattage ratings aren't true.Almost 10% less than Leos.
                  • Basstronics
                    • Jun 2008
                    • 2303
                    Neither is the KV. My 2400 kv is only turning 2200kv...
                    I realize there is some margin of error but I would assume it to be much tighter than this...
                    Amps... 80amps and its rated to 130. Thats it. After 80 amps there is no performance gain.
                    • jkr
                      FE Addiction
                      • 568
                      As said only the 56xx-58xx because of the 6pol rotor.
                      It is hard to beat Leos on this price range at 4pol.
                        • 9479
                        Ratings are bogus.. My TP motors runs way better than my Leopard in my DF33
                        How do you know it's 2200 not 2400
                        Do you have the right timing on the TP ?
                        • Basstronics
                          • Jun 2008
                          • 2303
                          #27
                          Because someone with the tools tested the motor and that was the results.
                          Im not 100% where the timing is, but I believe its been tested on a few settings available on my esc. Trust me, person working on this boat knows his stuff.
                            • 9479
                            #28
                            does not add up to what others including my self are seeing with these awesome motors
                            • gerardobrandao
                              • Mar 2008
                              • 164
                              #29
                              TP Power Motors
                              Hello guys....
                              Concerning quality, and having in the past, Lehner, Hacker, Neu, Plettenberg , Feigao, Mega Motors, i just can say that concerning Price/quality ratio are very good motors!
                              There assembly quality, and material quality seems fair for the price!
                              There are TOP league motors, that everyone know!
                              Hacker,Kontronik,Plettenberg,Neu and Lehner....PERIOD...
                              But you pay what you get..... You can´t have an high quality motor, like Lehner or Neu, without paying their development, Special steel stator, bearings quality, magnet quality, cooper winding quality, for the price of an feigao.....
                              Lehner motors have a efficeincy, in some motors above 96%...do anyone know what this means?
                              At 5000 watts absorving power we have 4800 watts converted in to mechanical power and 200watt dissipated as heat!( Nice soldering iron by the way)
                              At the same given absorving power, with an efficiency off 85%, wich isn´t bad, we have 4250 watts converted in to mechanical power and 750 watt dissipated as heat!....Many small room house heaters have this power......
                              Of course we are talking about Continuous Power, and not peak power....That´s why an industrial motor that weights 30 lb provides the same power, but works 14 hours a day,in mine case or even 24.....
                              For the ones that want to compare the quality of TP Power motors you have some videos of it:
                              We are comparing the twin 5850 in a 240cm hull length againts the cream of a crop lenher 3080..
                              Tp 5850
                              Lenher 3080
                              Considering that 1 TP 5850 costs 215€ and a Lehner 3080 costs 630€ aprox....You get mine Point..
                              It´s not the same thing, i know...but
                              • ManuelW
                                • Oct 2010
                                • 743
                                #30
                                Hi Gerardo,
                                what do you mean with
                                The boat is a Mystic 240 from mudl (Helmut D.) from PBF Passau. Do you know him or supporting him?
                                regards,
                                Manuel
