Flex coupler (2.5mm & 2.3mm)
  • latinwindow
    • 37
    Hi,
    I am in urgent need to make a flex coupling between a 2.5mm solid shaft and a 2.3mm motor shaft.
    Questions:
    1. What flex cable (width) do I need?
    2. Where can I buy the 2.5mm to flex, coupling
    3. The 2.3mm to flex, coupling
    I am in an emergency here. Many thanks.
  • Steven Vaccaro
    • 8723
    I dont know of anything commercially available. You can have the couplers made by a Guy named Ned S. I'm not sure how long it will take or cost. The flex size would depend on power used. I would think .130
    If your not in a hurry shoot me a pm and I can get you his email.
    • latinwindow
      • 37
      Thanks Steven,
      I am running a brushless 380 motor (between 3500 to 5200 KV)
      It a little devil!!!
      So do you still think the .130 flex cable can do?
      Yeah sure! I know there nothing commercially available - thats why I came to the post here - you guys always know the way out to 'dead ends'!
      Thanks!
      I will write you a PM... for this person's email.
      Sam
      • Steven Vaccaro
        • 8723
        Sam I will pm you Neds email add.
        • latinwindow
          • 37
          Thanks Steven!
          I have sent him an email...
          Do you think the .130 flex cable can handle the electric motor i specified above?
          (I am new to flex-shaftin)
          Sam
          • Dr. Jet
            • Sep 2007
            • 1707
            I have been running such micro motors with 2.3 mm shafts and 0.098 cable is plenty. I am having success using 0.030 wire drives as well. MHZ makes a 2.3 mm x 2.0 mm coupler; you can ream the 2 mm end to whatever size you need if you know someone with a lathe.
            A nation of sheep breeds a government of wolves
            • latinwindow
              • 37
              Thanks Dr Jet! I saw those couplers from MHZ - it gives me an idea! The only problem is dont know anyone with a lathe. !!
              I am trying to see if i can get them custom made by Ned (as per Steve's) advice.
              Sam
              • Dr. Jet
                • Sep 2007
                • 1707
                I just happen to have a little Taig and a 2.3mm reamer if you need it. Here's a thought: You could bore the 2mm end out to 3/32", install a brass tube (1/16" I.D.) with a hole for your set screw, and Voila! A wire drive coupler to fit 2.3mm shafts. I've done it several times already.
                • latinwindow
                  • 37
                  Got the couplers from Ned S.
                  man, one word AWESOME!!!
                  Thanks guys,
                  Thanks Ned S
                  Sam
                  • Jeff Wohlt
                    • Jan 2008
                    • 2716
                    That is the best way. Neds are top notch and will hold.
                    www.rcraceboat.com
                    [email protected]
