Drive shaft Help
  • gfm1135
    • Aug 2012
    • 170
    Drive shaft Help
    I need to change out the drive shaft from my 22.5 Arowana. I am running a Leo 2860 3400 kv on a 3s. What stuffing tube and drive shaft tube should I use. Strut?
  • Basstronics
    • Jun 2008
    • 2345
    I had this same dilemma with the one I had.
    Some people have used the Super V 27 strut, but its pricey.
    I opted to get the 4mm stinger thats 55mm long. I then took the bushing out and put a 1/4" reamer thru it so I can use 3/16" bushings/shaft.
    http://www.hobbyking.com/hobbyking/s...ive_Black.html
    I chose that one because Ive had one before and the color matched the rudder. Also because its a sealed design. The round part where the shaft goes has a ball which fits into a socket. So no worry about water getting between that area and the hull and coming up the stuffing tube like other designs.
    For cable I would advise a wire drive in this application. You can buy one from a few vendors now or make your own with the Octura propshafts- which are REALLY nice. Just beware you need the correct loctite glue to build these and its about $16...
    SirBudman32 can probably show you pictures of final product. Stinger fit very well on back of the boat too!
