Any tips for soldering motor & ESC wires to 8mm Castle connectors ?
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /Mono -
Tony my brother, ditch the torch and get yourself a iron.MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169Comment
My way is to tin the wire and then set it aside. Then I fill the bullet and while keeping heat on it I'll hold the wire on the iron tip as well until it also flows which is when I submerge the wet wire in the pool.
I do it this way on all sizes and have never had one de solder.
I had found that if it submerge a tinned wire directly, without flowing it, in to the pool they will sometimes cold solder.
Jmo.
All with a weller station. Can't use a torch to save my life.white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1Comment
Ive started to use flux on a few of my 10 gauge wires.
Silver Solder is HARDER to solder, its "Flux" is almost non existent, which is how its supposed to be. your basically heating up metal to put onto metal.
I think you need to tin both ends.
Wait till it cools down.
then heat up both ends again, then join parts together.Comment
Tony, unless you have 200W iron I would use the butane torch. The large solder connections suck up so much heat a small soldering iron rarely allows good solder flow around the entire joint.
I used a propane torch on low and use liquid flow on new wire to help the solder flow into the wire. I use a dud mating connector in a small jewlers vise to hold the connector I am soldering away from the vise slightly. I align the holes in the solder cup horizontal to try and keep the solder in when I feed it in. If you use rosin core solder you'll notice extra flux dripping out the bottom which tends to catch fire. Pause if this happens and wipe up the flux with a paper towel and then resume with the heat. I use an aligator clip on the end of a pipe of steel wire to hold the wire in place without burning my fingers. I pre-tin the solder cup just enough to have good coverage, but not trying to fill empty space. I then insert the wire and directing the torch towards the end of the connector gently heat the entire connector up. Once the pre-tin starts to melt I feed in rosin core 60/40 solder pausing to wipe excess flux up to prevent small fires. I like to feed in the same direction of the wire going into the connector on the top, this seems to trap more solder in the cup instead of dribbling out the holes or the bottom of the cup.
I would not use silver solder, that is more for mechanical brazing than electrical connection.
TGTyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WRComment
Jason, it's a 4S2P setup running a Leo 4082 2000KV in a 34" Cat with a 447/3. After digesting the info here, I'm convinced that I didn't prep (tin, heat and flux) the motor wires enough before I placed them in the liquid solder pool in the connector.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /MonoComment
I used a propane torch on low and use liquid flow on new wire to help the solder flow into the wire. I use a dud mating connector in a small jewlers vise to hold the connector I am soldering away from the wire slightly. I align the holes in the in the solder cup horizontal to try and keep the solder in when I feed it in. If you use rosin core solder you'll notice extra flux dripping out the bottom which tends to catch fire. Pause if this happens and wipe up the flux with a paper towel and then resume with the heat. I use an aligator clip on the end of a pipe of steel wire to hold the wire in place without burning my fingers. I pre-tin the solder cup just enough to have good coverage, but not trying to fill empty space. I then insert the wire and directing the torch towards the end of the connector gently heat the entire connector up. Once the pre-tin starts to melt I feed in rosin core 60/40 solder pausing to wipe excess flux up to prevent small fires. I like to feed in the same direction of the wire going into the connector on the top, this seems to trap more solder in the cup instead of dribbling out the holes or the bottom of the cup.
TG2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169Comment
Jason,
I'm with you on that; it's just that I built this for a customer and figured a little overkill would keep things in the safety zone.
From everything I'm learning here, particularly the first link in Doug's post I realize that I've been making some errors in my soldering that won't be repeated in the future. Live and learn.
Thanks everyone2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Here is a great iron for the price i have 2 of them. its a Hakko 936 knock off
http://www.hobbyking.com/hobbyking/s...h_US_Plug.html
Jason SimsComment
