Any tips for soldering motor & ESC wires to 8mm Castle connectors ?
  • properchopper
    rcgoatbuild@snotmail.com
    • 6968
    Been having trouble with wires coming out of the solder joint. I usually fill the connector with solder using a small butane torch and insert the wire inside while the solder is liquid, then let it cool and finish off with a soldering tip. I use 62/36/2 solder. I guess I could have doubled over the wire end; the hole in the 8mm is LARGE. Any better ideas that has worked for you ?
  • dana
    Banned
    • Mar 2010
    • 3573
    When exactly are they coming lose tony? When running?
    • jkr
      FE Addiction
      • 568
      The wire is coming out with the hole solder?
      I use flux and solder on the wire before i do the joint.
      • properchopper
        • 6968
        Customer's boat. Ran great, brought it in. Next power-up it cogged.
        • dana
          Banned
          • Mar 2010
          • 3573
          Hmmm... Have you tried 60/40 solder? Or solid silver solder?
          • properchopper
            • 6968
            That's what I did when I repaired it this morning. When I removed the original connectors (Leo 4082) using a torch, I assumed (yeah, I know ) that there was enough "tinning" on the bare wire end to suffice. Still, the 8mm connector's hole leaves a lot of open space to fill with solder. I'm considering crimping/soldering some brass tubing on the bare wires to step up the diameter of what gets inserted into the bullet. Hmmmm...
            • properchopper
              • 6968
              My thinking is that the extra 2% silver in the 62/36/2 solder would make it a bit stronger than the regualar 60/40 stuff. I'll have to look into the silver solder issue; haven't tried it so I'll have to learn about it.
              • dana
                Banned
                • Mar 2010
                • 3573
                Can I ask what Leo motor? Prop? Cell count?
                • jkr
                  FE Addiction
                  • 568
                  Try to make raf surface in the connector.
                  I also use 60/40 solder iwith no problems.
                  • siberianhusky
                    • Dec 2009
                    • 2187
                    Are you putting some heat to the connector after you put the wire in? Might be getting a cold joint at the center of the big hole. Lots of surface area to heat with those big un's
                    • properchopper
                      • 6968
                      I keep the torch on the connector to keep the solder liquified while I insert the wire. I think better tinning of the wire end is one step I can do better.
                      Here's something I found :
                      As a starting place, for most small electronics soldering, 1/32 inch (.03) rosin-cored, 60/40 (tin-lead) or 63/37 solder should work fine. Rosin-cored lead-free is fine, too. Unless you have reason otherwise, don’t use “no-clean” solder–it’s very likely that you don’t need to clean the regular rosin-cored solder. The solder should be thin enough to prevent […]
                      • dana
                        Banned
                        • Mar 2010
                        • 3573
                        Anyways, seems like desoldering issues can only be fixed one way. A different setup. Jmtc
                        • properchopper
                          • 6968
                          This boat ran with cool motor and ESC temps and used a very moderate amount of mah. The setup was mild. My soldering sucked, pretty sure that was all.
                          • dana
                            Banned
                            • Mar 2010
                            • 3573
                            Oh, we'll bad soldering is a problem lol. Given the small amount of info you have it's hard to diagnose that. Sounds like you solder like I do tho... And my stuff is ok. I do tin motor leads very well first tho, and I don't bother with a soldering iron after. All torch buddy
                            • numse1964
                              • Oct 2010
                              • 37
                              Hi
                              Be sure your cable is hot. You must use quit big cables for these connectors, and they will build a cold bridge if they ain't about the same temp as the solder and connector.
                              Best regards Henrik
