Esc caps on fire
  • dana
    Banned
    • Mar 2010
    • 3573
    2200kv with m440 IMO. If all is good go to m445
    • yfzbrad
      • Jun 2012
      • 34
      Originally posted by dana
      It's 24mm and yes it does
      Sorry I meant between a 3674 and a 4074 I now know I screwed the pooch on buying the 3650... Live and learn I guess... It's only money...
      • dana
        Banned
        • Mar 2010
        • 3573
        You could run the 3674 on the 120. You would need to upgrade esc if using the 4074
        • yfzbrad
          • Jun 2012
          • 34
          Do you happen to have a educated guess on about how many amps the 2200kv 3674 pulls?
          • Serpents811
            • Oct 2011
            • 381
            you will be just about maxing out the t120 as far as amps goes
            • dana
              Banned
              • Mar 2010
              • 3573
              Depends on the prop
              • Serpents811
                • Oct 2011
                • 381
                i had a 3674 2200kv on my old rigger pulling over 120amps
                • yfzbrad
                  • Jun 2012
                  • 34
                  #23
                  So t180 or what about the swordfish 150?
                  • lenny
                    • Sep 2010
                    • 4294
                    #24
                    I am using the 4074 2200kv Timing at 15 with a T120a esc with 3 more 35v 1000uf caps with a x646/3 prop,
                    In a modded to FE 36"PB Shockwave mono and all stays cool on 4s2p a 42 mph.
                    ? ONLY IF THEY WORK
                    • keithbradley
                      • 3663
                      #25
                      I thought your setup was 3s until I read further down. Generally guys limit 4s "sport" setups to 2200kv, and reccomend a 200A+ ESC for doing so. I would also reccomend a larger can and lower kv, but no matter how you do it, your ESC will limit your potential power.
                      www.keithbradleyboats.com
                      • Make-a-Wake
                        FE Rules!
                        • 5557
                        #26
                        OK, so now you know you had a small motor with high kv, but moving on, the 3674 2200kv on 4s is a huge upgrade especially if you get a 4 poler like a Leopard. You can run the T120a ESC with that setup all day long if you keep the prop at an x442 or less. I ran it in a Mono and your cat will pull less amps. To answer your ballpark figure, I think the setup i mentioned above will pull around 90-100 amps with an x442.................so you will be putting out around 1400 watts, or 2 hp...........big power for that hull! It'll get you over 50 mph. The 4074 is even more overkill and will not yield much more speed.
                        • yfzbrad
                          • Jun 2012
                          • 34
                          #27
                          Thanks wake...I was worried about putting up my post and looking stupid. But for the most part I got some good info... all the members of this forum
                          Rock but you and keith and some of the other more experienced members are in a different league...
                          • 785boats
                            Wet Track Racing
                            • Nov 2008
                            • 3169
                            #28
                            If you do go with the 3674 2200kv Leopard or Turnigy, be sure to drop the timing on the ESC to 1-3 degrees. They are D wind motor & don't like a lot of timing. 15 degrees will not do it any good at all.
                            All the best.
                            Paul.
