I have a few questions..
1. What type of Lube is the best for the Flex Shaft?
2. How often should I lube the shaft?
3. I need a New flex shaft.. To much power and spun the last one.. So where do I find one of those and what measurements do I need to take?
4. I need a Dual water pickup because the temps I feel are to high.. I need a single 4.5" dual water rudder pickup. Also where do I get one?
5. I also need the brass or copper little insert that gets glued into the boat, basically the part that connects to the hose from the rudder.. I need 2 of those and need to drill 2 more holes. I will post some pics.
6. Plastic insert where pic is takin, between motor and flexshaft tube.. Can that be replaced
Currently I am running 1-8300 MAH at 6s, with Hydra Ice 2 HV200, Motor is unknown.. But I do have 2 batterys in the boat to stabilze it..I should be able to get 60mph all day with the setup I have. I bought the setup without a ESC and battery, the seller said he ran 6s before but not sure.. I plan on setting this up with 6s and getting it to run great and then switching to 12s system and run 80-100mph.. I will get some videos, these batterys are so heavy its crazy and expensive..
Anything else I should be careful of? or helpful tips, first time boater but I have rc airplanes, but they are gas, not electric.
