corrosion x
  • meangenesracing
    • Jun 2012
    • 1164
    corrosion x
    sprayed my castle hydra hv200 esc 24 hours ago should i clean off the excess corrosion x that has not driped off from hanging thanks, geno
  • Serpents811
    • Oct 2011
    • 381
    • Mike Caruso
      • May 2012
      • 940
      Originally posted by Serpents811
      Oh boy not the stuff to use?
      Do It Like You Mean It .....or Don't Bother
      • Jason4636
        • Jun 2012
        • 654
        I use corrosion x on all my electronics. I don't wipe off any of the excess
        • RandyatBBY
          • Sep 2007
          • 3915
          Strange I have used it on my Schultz's works great! I use it on all my electronics too. Never a glitch.
          Randy
          BBY Racing
            I've used CorrosionX on my electronics - receivers, servos, ESCs - for years with zero issues. I flood the boards, shake off the excess and let it air dry. It can be removed for repair, unlike many of the "conformal" coatings. Too, it is cheap and easy to re-apply.
            • gyrotron
              • Jul 2012
              • 481
              Please explain the appropriate use of corrosion x
              • driftah
                • 760
                I fill a cup with the liquid then dip whatever exposed electronics in it then drip dry then use,It actually eats prior corrosion and prevents further corrosion,works amazing on stuff even in the snow...using it for years also heh.it is non conductive methinks also, so zero issues and it wipes off fairly easily...stuff is magic.
                • Jason4636
                  • Jun 2012
                  • 654
                  I'm like the other guys, spray it on let it drip dry for a day. The use it
                  • gyrotron
                    • Jul 2012
                    • 481
                    When you talk about the use of corrosion x on electronics are you including the motor? Can it be used on the inside of brushless motors after you have previously cleaned it?
                    • JimClark
                      • 5907
                      yup it can
                      Some even buy gallons of it and let the motor soak in it
                      Billy Graham
                      • Jason4636
                        • Jun 2012
                        • 654
                        Like Jim said, even on motors
                        • gyrotron
                          • Jul 2012
                          • 481
                          Originally posted by JimClark
                          yup it can
                          Can this be considered standard procedure before maiden run?
                          • JimClark
                            • 5907
                            In between maintance for the motors before run for the electronics
                            Billy Graham
                            • RandyatBBY
                              • Sep 2007
                              • 3915
                              I have seen several ways to use it.
                              The nitro boys use it on servos in the hot pits in practice when a boat comes in with wet radio box. They pull the servo out and apart spray the motor and circuit board shake off excess and water. Then they put it back together and in to the boat and they work correctly.
                              I like to soak the OPC motors in it after a dunk. It is great to save ball bearings and prolong life of them. On some receivers it is necessary to let drip dry over night. ESC's Spray and use.
                              Randy
                              BBY Racing
