I'm throwing this out here to get some feedback from anyone with actual experience with this issue.
setup:
IB-34
T-180 - timing 3.75 deg - modded "full chamber" cooling block w. dedicated water pickup & Ettie cap board - NO LVC
Neu 1521 1.5D
4S2P 5000mah Dinogy 65C/130C
X450/3 & X447/3
9.5 lbs. rtr
mill + 6 laps (maybe 3 min. )
Started a few months ago; test/tuning and boat slowed down a bit. Sent motor to Neu; was fine (new bearings & rotor rebalance & endplay re-done to spec).
Put in spare motor.
Raced Sunday - HOT HOT air & water temps) Stephen's EXACT same boat slowed way down after a few laps. Went down to the X447/3
I did the same - X447/3. Last heat coming up to the finish line (@200 feet) boat slowed to a crawl. Limped across for a Second Place Class win behind Tyler's similarly powered (but with a CC240). Tyler rocked a First in P-Ltd Sport Hydro (& P-Mono with a Perfect 1600 points) btw, GO TYLER
Stephen's under the impression that the T-180 has a thermal protection circuit; I wasn't aware of that ( then again I just heard the news about Elvis
). If so, the hot day was the cause of the slowdown in what otherwise has been a completely reliable setup. Oh, the caps were @ 165 deg; esc @ 160 deg.
And on an irrevelant but curiously ironic note, I spent two days pitting for a super nice Rigo Bustanante (RC Boatworks). I now have a sore shoulder and arm and an open sore on one finger from repeatedly yanking on that go-handle and a cute pipe burn on my arm.
Dem gas boats are a whole 'nother thing
setup:
IB-34
Neu 1521 1.5D
X450/3 & X447/3
9.5 lbs. rtr
Put in spare motor.
