New boat!!!
  • twissted
    • Jul 2012
    • 867
    New boat!!!
    House Cleaning
  • Make-a-Wake
    FE Rules!
    • 5557
    Wow........................sexy gal there!! Thought it was a Genesis knockoff at first but nope, quite a bit different. Screaming for 4082's on 6s!!!!!!!!
    • Make-a-Wake
      FE Rules!
      • 5557
      Outta be quite fast as-is though...........the 4082's just popped in my head.........................Very nice
      • Basstronics
        • Jun 2008
        • 2345
        Jan @ knitec has same boat for $650.
        Dont know how bad shipping hit you from China...?
        • martin
          • 2887
          Dont forget to run an external aerial on the rx in a carbon boat.
          • Flying Scotsman
            Fast Electric Adict!
            • Jun 2007
            • 5190
            You may be disappointed with the speed, as that is a big hull. You will need a lot of battery juice and very good ESCs and the motors may not cut, it might work on lower KV motors and 8S, prop selection etc.
            Douggie
            • twissted
              • Jul 2012
              • 867
              House Cleaning
              • ron1950
                • 3024
                nice boat keep us advised on performance pls....
                • twissted
                  • Jul 2012
                  • 867
                  House Cleaning
                  • twissted
                    • Jul 2012
                    • 867
                    House Cleaning
                    • twissted
                      • Jul 2012
                      • 867
                      House Cleaning
                      • Make-a-Wake
                        FE Rules!
                        • 5557
                        Originally posted by twissted
                        the antanna isn't enough?
                        Martin was saying to make sure you have some external antenna as the hull will block the signal, some 2.4 ghz systems have a small antenna on the receiver, it would slide right up into the red tube on your boat.
                        • lomdel
                          • Nov 2008
                          • 708
                          I will also follow this build with interest! Cool rudder that. How would the servo set-up for that look? With the Hobbyking 180's and a decent servo, this would work out to be an expensive build...
                          • keithbradley
                            • 3663
                            It looks like the boat has a 115mm rudder on it...very small for a boat that size. An upgrade in rudder in probably a good idea. Do you know that you can buy just that hull there too? Sometimes it's best to buy just the hull if you plan on upgrading it anyway. The motors will likely need to be mounted in a different place if you end up upgrading the power system.
                            www.keithbradleyboats.com
                            • Rocstar
                              Joel Mertz
                              • Jun 2012
                              • 1509
                              Keith, what rudder would you recommend for a pull / pull setup?
