i appreciate all the input guys… but sometimes its just time to move on. im sure it can be made rite, but im tired of tinkering
POS df 26 wont turn nicely… bout to run this thing over with my car
Doesnt look that bad................
Can you try raising your strut and maybe run a larger diameter prop to get the butt to set in more?NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
I was going to say that but didn't want to risk getting flamed about it. It seems to run pretty well in the straights and if you're only sport boating I don't think it's that big of an issue.Bling rocket 32" T600 1400kv on 6S, Twin Lynx 3126 2200kv on 4SComment
Can't see the video, but one easy fix is to add a larger turn fin. One symptom of a too small fin is hopping in the turns. Several club members had this issue, all solved it by increasing the fin size - sometimes dramatically. Turn fin size depends on the water (rougher needs bigger) the weight of the boat, the speed of the boat in the turns, and the radius of the turns. As others have stated, the CG can be a player as can strut depth. The DF26 is an awesome-handling model, you should be able to get it to run great....if the turns are not too tight. It is a race boat after all.
Off topic, but your water inlet is configured wrong - it should enter the motor jacket at the lowest point and exit on top. The way it is configured in the first post the jacket may not be full. Most of us run the cooling water to the ESC first too....
I notice in post one, second picture that the strut is all the way down, try it about 3/4 of the way up and give it a tad of negative.............you need to get the Butt to plant.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
thanks everybody for the help and words of encouragement. im feeling a bit better today about this thing. in the pics, the strut was actually up a bit, i tuned it down yesterday and got a run in, and actually it ran a bit betterr. but i also moved the packs back. i have a larger set of turn fins on my titan i will take off and try them on the df. if thats the solution i will be a happy man, or at least fix the problem before i sell to someone. we'll see….
i def see the front plowing in when i turn… i will try an x444 today. one thing i do love about this boat is that there is so much motor… it doesnt even break a sweat after a solid run…. i know the potential is here.Comment
A couple of things.
As previously stated, get the rudder vertical.
Round off the front bottom corner of the rudder to about a 1/4" radius. This helps to reduce lift.
Put an X440/3 blade prop on it. I find that 3 blade props result in a much more settled boat in the corners.
Although your fins look large enough a larger one will help, as Fluid suggests.
The COG may need to come back a bit. If that then tends to lift the nose too much down the straights you can put a slight bit of negative in the strut. That can also help stop the hopping in the corners.
Here's a couple of pics of mine if it helps.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
Now that I can actually see the video, Make-a-Wake is right - that isn't bad. The model airs out nicely on the straights so the CG is probably not bad, particularly since it does not bow-steer. This is a race boat designed for 35-foot radius turns, the OP is trying to turn twice as tight...and even then the boat does not behave badly...he is able to drive through it without problems other than a little bounce when he tries to turn really tight. Put it on a race course and it would be a winner. As I stated in my post above: "you should be able to get it to run great....if the turns are not too tight".
Problem solved.
Yeah, it does look good Jay, i think he could still raise the strut a bit and give it a 'tad' of negative..................try that Dana!!NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Guys, I can't thank you all enough.
I got a run in with the larger turn fins and the x444. Also I put the rudder all the way in and WHOA! It ran like a CHAMP!!! I'm so friggin ecstatic I'm glowing! That sucker turned on a dime without hopping at all -).
Soooo much better it's like night and day
Now the video posted wasn't terrible, but that run wasn't a great representation of how bad the hopping can be.
I turned the endpoint down a bit on my steering channel so it wouldn't carve as tight, but I assure you it carved turns like it never had before. I also moved the batteries back a full inch from where they were before.
I'll get some vid tomorrow for sure.
I'm so happy... If I only knew that larger turn fins would help that much I could've saved myself lots of aggravation.
I will be ordering several new props as I've lost 5 this summer due to my mistakes and sticks in the water.
I think another x640-x440/3-maybe x642? Any other suggestions? Thanks again boysComment
I tried a X438 in mine and didnt care for it. I had decent results with the K42 glass filled props. If you got them to try, go for it.
I never did get to try the X440/3. I got a real nice one that Blackcat26 did, and man it is NICE. I hope to put it on something sooner or alter.42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP)Comment
Here's video from today running strong finally
Nos, thanks I'll take it -)Comment
