POS df 26 wont turn nicely… bout to run this thing over with my car
  • dana
    Banned
    • Mar 2010
    • 3573
    ive about had enough with this stupid thing. no matter what i do the transom hops in and out of the water when i turn it. its been 4 months of tinkering and ive tried everything i can think of and nothing changes. is my rudder too long? should i bring the strut in? batteries in the wrong place? someone please help before i destroy this *!***!***!***!**ing thing in a rage. im not new to boats…. and have plenty of nicely running boats. this thing just fellates cattle. heres some pics please help!!!! IMG_2678.jpgIMG_2684.jpg
  • dana
    Banned
    • Mar 2010
    • 3573
    motor is 4074 2200kv, prop x640 and x440 (no difference in turning) seaking 180 esc
    • dana
      Banned
      • Mar 2010
      • 3573
      does someone have a nice running df26 that can post pics?
      • egneg
        • 4670
        The rudder is set wrong - it should be neutral at a minimum.
        IMPBA 20481S D-12
        • dana
          Banned
          • Mar 2010
          • 3573
          ive adjusted the rudder every which way. doesnt make a difference
          • dana
            Banned
            • Mar 2010
            • 3573
            i figured kicking it back would reduce some of the lift
            • dana
              Banned
              • Mar 2010
              • 3573
              should i lower my strut?
              • martin
                • 2887
                Where is the cg, looks like you have a lot of weight foward. It needs to be around 8" from the transome as a starting point.
                • lenny
                  • Sep 2010
                  • 4294
                  I think your cells should be back at the transom,
                  And the rudder at neutral or a little forward to help with the turning some.
                  Have any video of it running ?
                  ? ONLY IF THEY WORK
                  • Serpents811
                    • Oct 2011
                    • 381
                    • keithbradley
                      • 3663
                      It's the other way around.
                      I put one together and it cornered at 45mph+ as tightly as I wanted.
                      Set CG at around 30% and put some longer turn fins on it. Those are mounted too high for their size. If you go up in size (or mount them lower) you can angle them back a bit, so when you turn a larger area carves into the water, instead of a small tip of the blade. Give it a shot and I bet you love it. This boat should corner like it's on rails.
                      www.keithbradleyboats.com
                      • Basstronics
                        • Jun 2008
                        • 2345
                        I had a copy that ran awesome and was on rails!
                        I dont have a side shot, but here it is from the back:
                        My rudder had a radius on the bottom as well.
                        Dont laugh, but I ran this thing at 50% COG without a hiccup. Motor was a 2868 2989kv and 3s29 4400 total, 42x1.4 plastic prop:
                        • Make-a-Wake
                          FE Rules!
                          • 5557
                          I think we are all wondering where the COG is, i bet its the culprit
                          • RaceMechaniX
                            • Sep 2007
                            • 2833
                            CG does look awfully far forward. Here are pics of my DF26 N2 heat race boat. It's also the current 2-lap record holder at 27.3 seconds so I can safely say it turns pretty damn good.
                            My batteries are mounted about mid way relative to the motor coupler.
                            Tyler
                            Tyler Garrard
                            NAMBA 639/IMPBA 20525
                            T-Hydro @ 142.94mph former WR
                            • dana
                              Banned
                              • Mar 2010
                              • 3573
                              no tabs or fins huh? looks good tho.
                              my batteries were at 8 1/2. i moved them back to 7 3/4 and buried the strut, and it was actually better.
                              i think im done screwing with it tho. prolly just gonna sell it
