How do you fasten your hardware?
  • flyboy320
    • Mar 2008
    • 88
    Wondering the best way to fasten hardware to the transom. I see several options
    1. screws
    2. bolts with standard nuts
    3. bolts with nylock nuts
    I'm talking about the rudder, strut and turn fin.
    Cheers...
  • Doby
    KANADA RULES!
    • 7280
    #3, with washers to help spread the load.
    Grand River Marine Modellers
    • Eyekandyboats
      • 1921
      i lay 1/4 inch ply on the inside of the transom along with epoxy in between.
      then i tap my holes and screw in screws.... yes screws. That way if my hardware rips off because of a log, turtle, or any of that crap it doesn't rip the transom apart. the screws simply pull out.
      EYEKANDYGRAPHICS
      www.rclipos.com
      • Flying Scotsman
        Fast Electric Adict!
        • Jun 2007
        • 5190
        Another question, how do you make a watertight fastener connection on the transom. I use cable grease. What do you use?
        Douggie
        • G Doggett
          • 446
          Same as Eyekandy I have plywood inside the transom but fasten the hardware with stainless bolts and blind nuts.
          To prevent damage to the transom if you hit something I use a 'breakaway' rudder that pivots on just one bolt and the same with the turn fin.
          Seal the bolts by smearing RTV on the threads.
          Graham.
          • Doug Smock
            Moderator
            • 5272
            Are you building the "Pickle" flyboy? If you are, screw the strut and turn fin brackets and bolt on the rudder bracket.
            Doug
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • Flying Scotsman
              • Jun 2007
              • 5190
              Douggie
              I will pose the question again. How do you make the connection watertight??
              • Mich. Maniac
                Banned
                • 1384
                I use washers on the inside that have rubber on them. so far no issues, everyone is different though.
                • Doug Smock
                  Moderator
                  • 5272
                  A little dab of silicone on the screws/ bolts.
                  Doug
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
                  • flyboy320
                    • Mar 2008
                    • 88
                    Doug
                    Yup, thats the one
                    Its in the mail, and hopefully will arrive soon...
                    • Doby
                      KANADA RULES!
                      • 7280
                      Silicone, it has more uses than just for California blondes
                      • z400
                        • 1311
                        some of my stuff is just screwed in with no nuts or anything
                        my rudder is screwed in with a washer on the end of each screw with a nylon locking nut
                        my strut is screwed in with those tee nuts that sink into the transom
                        i've got a piece of 3/16" birch plywood that was cut to fit my transom form
                        epoxied in and sealed
                        i use silicone each time on the screws if i remove them
                        Z
                        KBB34" Mono - Fast
                        ToySport Triton- Not as fast
                        • Eyekandyboats
                          • 1921
                          tap the hole with a ... tap and you do not need any silicone
                          EYEKANDYGRAPHICS
                          www.rclipos.com
                          • Doug Smock
                            Moderator
                            • 5272
                            Tight or under sized holes will keep water out of the hull, but it won't keep it out of the transom doubler. The ply will begin to rot as there is no way for it to dry. A little silicone will go a long way to keep the transom in good condition..
                            Doug
                            MODEL BOAT RACER
                            IMPBA President
                            IMPBA 19887L CD
                            NAMBA 1169
                            • Flying Scotsman
                              • Jun 2007
                              • 5190
                              The consensus definetly favours silicone. I thought of using that but I was under the assumption that it would be a permanent bond as silicone is difficult to remove and does not adhere well to itself after curing. How do you remove the old silicone??
                              Douggie
