New 37" daytona from fightercat.
  • ls1fst98
    • 859
    Just got my 37" cat in last week and have been tossing around setup ideas in my head. I currently have a pretty stock sv27 with a ul1, an aeromarine cat with a single turnigy t600 1400kv brushless and I have an extra 1400kv brushless. My thought was to put the stock sv motor back in, put the ul1 in my aeromarine and run twin t600 1400kv in the daytona, unless there's a better single option fir it. I like the idea if being able to run both the sv and the smaller cat on 4s lipo and buying new packs for the daytona.
  • Jeff Wohlt
    • Jan 2008
    • 2716
    You will need some power for that hull. Forget any SV or UL motor...too small and will just work it too hard. The outrunner T600 1400 is ok or just get you a 4082 1600KV and run on 4-5S with 180 amp Turnigy ESC. You will have a better and longer set up. M445-47 should turn it on pretty good.
    www.rcraceboat.com
    jwohlt5362@yahoo.com
    • ls1fst98
      • 859
      I know the sv and ul1 aren't enough for the genesis, what I was saying is use the ul1 in my mean machine and run twine t600 1400 kv on 5-6s each
      • LOVE6S
        • May 2012
        • 545
        How fast does the two t600 motors push the mean machine?
        • Prop-a-Gator
          • Feb 2012
          • 163
          @Love6s: I think he also mentioned the mean machine was a single.
          @ls1fst98: JJ2003 here on the forum built a twin T600 1400kv Daytona. Here's a link: 37" Fightercat Daytona Carbon Fiber Catamaran LE #068 He also had a detailed build thread over on FCR, if you're a member.
          Disclaimer: I hereby accept the potential loss of motor, ESC, entire boat, or credit rating, and forfeit all expectations of success.
          • ls1fst98
            • 859
            Thanks prop, yea the mm is still a work in progress, that's y I could pull the one out and use the other I have on the shelf. I'll check it out prop, thanks!
            • LOVE6S
              • May 2012
              • 545
              I thought he said the MM was a twin, these are a big motor, must be tight in a sponsoon, I am a member at FCR I will check it out thanks, Shawn.
