Hi Guys Setting up my first electric boat, ( Insane FE 30 Sport Hydro ) and was just wondering which motor would be better Leopard 4074 or Leopard 4082 running a Turnigy 180 Amp ESC.
A 4074 motor in the 2200KV range on 4S will get you to the sixties. The 4082 is more than you'll need. The T-180 will work well with the 4074 motor. If you need any build/setup info, e-mail me at [email protected]
Tony
Hi abmarine Tony is awesome he has built me personally 3 insane boats and his building is top flight, I 2 fe30's one setup for spec raceing and 1 for sport racing and they run great, the 4074 is a good motor I have used it myself in this boat and as Tony says it will get you into the 60's.
These boats are fun with a capital F, have fun with it and follow Tonys advice you won't go wrong.
Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
Hey Guys thanks for all your help so far, Dont have boat yet but am getting everything together so that when it gets here, I can start the build, What flexi shaft size would you reccomend to run with a 4074 motor ??? 3/16 or 1/4
Tony, When you say 4s what MAH battery packs do i run ?? 4074 motor with Turnigy 180 ESC. Also were is the best place to get a leopard 4074 motor at a reasonable price ??
I run 4s2p 4000mah on my fe30 running the Leo4074 motor.
Tony
Tony,
A pair of 4S 4000 mah packs just fit under the deck. They'll give enough juice to make a mill + 6-lap race with plenty left over and the extra weight helps. I started out using the Turnigy 4S 4000's but have switched to the Dinogyshttp://performancerclipos.com/page8.php?view=productPage&product=4&category=. A few dollars more, but better batteries ('tho HK has an AU wherehouse).
