Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 Insane FE 30 Engine Recomendations - Offshore Electrics Forums
  • abmarine
    • Jun 2012
    • 13
    Hi Guys Setting up my first electric boat, ( Insane FE 30 Sport Hydro ) and was just wondering which motor would be better Leopard 4074 or Leopard 4082 running a Turnigy 180 Amp ESC.
    Thanks in Advance.
    Tony
  • properchopper
    rcgoatbuild@snotmail.com
    • 6968
    Tony,
    A 4074 motor in the 2200KV range on 4S will get you to the sixties. The 4082 is more than you'll need. The T-180 will work well with the 4074 motor. If you need any build/setup info, e-mail me at rcboatbuild@hotmail.com
    Tony
    • abmarine
      • Jun 2012
      • 13
      Awesome, Thanks Tony, If you can flick me through some pics of your set up that would be real cool, my e-mail address is abmarinenz@vodafone.co.nz
      Much appreaciated.
      Tony
      • TheShaughnessy
        • 1431
        http://forums.offshoreelectrics.com/...ne+fe+30+build
        check out this thread. Should answer just about any question you have.
        • properchopper
          • 6968
          Here's a bunch of FE30 builds I've done :
          http://forums.offshoreelectrics.com/...at-RCBOATBUILD
          • properchopper
            • 6968
            Here's one I did a few weeks ago with a spec motor ; used a .187 cable so a P motor could be dropped in later :
            Rear hardware with large servo rod pass-through to minimize rod-bind
            With bellows & water inlet
            Tubing away from prop
            Stuffing tube
            • properchopper
              • 6968
              Nylon shear bolt on turn fin
              Rounded bottom of rudder
              servo mounted
              Spec motor interior layout
              Gotta run B-back later tonight for questions,
              Tony
              • CHIEFY_44
                • Nov 2010
                • 254
                Hi abmarine Tony is awesome he has built me personally 3 insane boats and his building is top flight, I 2 fe30's one setup for spec raceing and 1 for sport racing and they run great, the 4074 is a good motor I have used it myself in this boat and as Tony says it will get you into the 60's.
                These boats are fun with a capital F, have fun with it and follow Tonys advice you won't go wrong.
                Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
                • abmarine
                  • Jun 2012
                  • 13
                  Hey Guys thanks for all your help so far, Dont have boat yet but am getting everything together so that when it gets here, I can start the build, What flexi shaft size would you reccomend to run with a 4074 motor ??? 3/16 or 1/4
                  Cheers Tony
                  • martin
                    • 2887
                    .187" (3/16") flex for 4074 motor. A 1/4" is way to big.
                    • abmarine
                      • Jun 2012
                      • 13
                      Tony, When you say 4s what MAH battery packs do i run ?? 4074 motor with Turnigy 180 ESC. Also were is the best place to get a leopard 4074 motor at a reasonable price ??
                      Tony
                      • CHIEFY_44
                        • Nov 2010
                        • 254
                        I run 4s2p 4000mah on my fe30 running the Leo4074 motor.
                          Silly question.
                          http://www.offshoreelectrics.com/pro...o-4074&cat=148
                          • jamie
                            • May 2011
                            • 179
                            I think OSE also do a Leopard 4074 T180 Package with the bullets installed for you.
                            • properchopper
                              • 6968
                              Tony
                              Tony,
                              A pair of 4S 4000 mah packs just fit under the deck. They'll give enough juice to make a mill + 6-lap race with plenty left over and the extra weight helps. I started out using the Turnigy 4S 4000's but have switched to the Dinogyshttp://performancerclipos.com/page8.php?view=productPage&product=4&category=. A few dollars more, but better batteries ('tho HK has an AU wherehouse).
