Connectors style question?
  • Steven Vaccaro
    • 8721
    I have to switch the manufacturer that I was using to make my 5.5 connectors. They are no longer in Biz.
    The new manufacturer offers two styles, one that similar to what I was currently selling with a hole in the back.
    One with a notch in the end. See the picture.
    Personally it would make it easier to use a bullet with the slot.
    But I'm wondering what you guys think?
  • LarrysDrifter
    Big Booty Daddy
    • May 2010
    • 3278
    Definitely the slot. Easier soldering. Faster soldering. No more solder flowing over the male end because too much solder was used. Newbie friendly.
    • G1ST
      • Dec 2010
      • 348
      Agreed, also better for a hydra 240 with twin leads.
      When would you have these available?
      Greg
      • carlcisneros
        • Jan 2010
        • 1218
        up to you Steven,BUT also look at the CONTACT area of the slotted one as opposed to the
        one with the thru hole in it. There is another manufacturer (name escapes me) that offers the slotted
        one with the same area contact as the thru hole ones.
        just a suggestion.
        The slotted one are deffinately easier to solder up.
        • tlandauer
          • 5666
          , the slotted one might be easier to use, however, I loved the discontinued version for one BIG reason: it is so nice to make parallel connectors out of them. I use a brass rod ( K&S) and connects three of them---soldered of course. One FEMALE flanked by two Males and the other is the exact reverse.
          • detox
            • Jun 2008
            • 2318
            I use slot style connectors with larger 8 gauge wire, but works good with any size wire.
            • battlefury
              • Sep 2010
              • 256
              How can we make parallel y connectors out of slot version?
              http://www.youtube.com/user/f4agusta09?feature=mhee
              • Steven Vaccaro
                • 8721
                All valid points. Maybe I will carry both.
                • martin
                  • 2887
                  Deff a place for both, as theirs those that prefer the slight ease of soldering the notch ones + those that need to make paralel or series conectors & need the other ones with the holes in the sides.
                  • Doug Smock
                    Moderator
                    • 5272
                    What's important to me is that the prongs or fingers on the male connectors are thick (strong), and that they are compatible with the connectors that I have been buying from OSE.
                    Thanks Steven!!
                    MODEL BOAT RACER
                    IMPBA President
                    IMPBA 19887L CD
                    NAMBA 1169
                    • 1945dave
                      • Mar 2012
                      • 304
                      Well perhaps we need to discuss soldering techniques to do either connector correctly. On top of that what type of solder do you use? Low temp electrical solder melts at a pretty low temp and can soften during use. I believe it is harder to use but I try to use hobby grade silver solder which is less likely to soften or melt during use. The trick is to not melt the insulation of the wire close to the connector. I attended a model show and saw a guy explain that we should wrap the end of the wire to be inserted into the bullet connector to make a snug fit before soldering. Then to tin both the inside of the bullet and the wrapped end of the wire. I am sure the most exacting modelers might do something like this.... are you one?
                      I might try to shoot some pictures to show you what they are suggesting. I prefer the solid connector but no hole.
                      Dave
                      • m4a1usr
                        Fast Electric Addict
                        • 2038
                        I dont think its too big an issue which ones to carry Steve. Few guys build more than one or two sets of "Y" adapters for their fleet. I mean whats the point? Your going run the whole fleet out on the water at once? Each person only needs 2 or 3 sets of adapters in their inventory so its a no brainer. Most of everyones needs for bullets is going to be for motors, speedos or batteries. Not for parallel adatpters. Carry both but I doubt the need for the ones with holes outweighs the need for the ones with slots. Which I like better IMHO since they allow for better solder mass retention. Just my dos centavos based on the current trend of global economic trends.
                        John
                        Change is the one Constant
                        • Heaving Earth
                          Banned
                          • Jun 2012
                          • 1877
                          Slotted
                          • Diegoboy
                            • Mar 2007
                            • 7244
                            Hole
