Heat
  • Mike389
    • May 2011
    • 9
    Heat
    FE Experts.
    Built a FE Tunnel out of a woodstuff hull. OS bottom end Aquacraft motor and swordfish esc. After running a FE IMPBA race (6 laps) the batteries 2 7.4 lipo's and wires are very hot. Any idea's would be helpful. Tried a few different props.
    Thanks,
    Mike
  • oscarel
    • Dec 2009
    • 2127
    You'd be surprised of the amps pulled with outboards. any idea where you are? What size connectors are you using?
    • Mike389
      • May 2011
      • 9
      Batteries are 4200's and attach with deans. Connectors on the motor are the stock bullets.
      I run the same batteries and connectors in my UL-1. The UL-1 flies around the course and everything is very cool.
      Also on the tunnel, I run two water pickups: one for the motor and one for the esc, both working. Also an oiler on the lower unit.
      • oscarel
        • Dec 2009
        • 2127
        I would definitely change out the deans. Since the outboard puts the prop further back it's going to be in the water more and will cause the amps to be higher. What props are you using? What C rating are the lipo's?
        • Mike389
          • May 2011
          • 9
          30C x440 3 blade is one I tried.
          • oscarel
            • Dec 2009
            • 2127
            How much did you put back into the lipos?
            • Mike389
              • May 2011
              • 9
              I will have to check. Raced three heats with 3 sets of batteries and have not recharged them yet. tried smaller and two blade props with no real difference.
              • TheShaughnessy
                • 1431
                Ditch the deans
                • Doby
                  KANADA RULES!
                  • 7280
                  Yup...tunnels seem to be Amp hogs........change over to 5.5mm bullets.
                  Grand River Marine Modellers
