Finally getting around to actually running my hpr115....
  • Remmie81
    • Apr 2012
    • 134
    The 45mm 3 blades should be good
    Hope you can quickly enjoy your boat
    • electric
      • May 2008
      • 1744
      You know, if you can shoot a short video of what it looks like in the water that might help everyone see what is going on.
      • vvviivvv
        • May 2009
        • 1079
        100% plan too, hopefully run it on tuesday as my car wont be ready till then.. or thursday as i have exam on wednesday
        Uk SAW record holder
        • ManuelW
          • Oct 2010
          • 756
          For props, I'd also start with the PropShop 47mm 2-blades.
          You can make a little bench test for the ESC's:
          If you connect them you should hear 6 beeps, indicating the number of connected cells. Then the status LED on both ESC's should be lighted. If you then give a little throttle the LED should switch of. The just give for a really short time full throttle at the transmitter, just less than a second is enough. Because at full throttle the LED's should switch on again. If they don't switch on the ESC's are programmed not correct to the transmitter and don't open 100%.
          But really just a short kick of full throttle.
          The rest of the photos looks fine so far, no huge mistakes or problems visible.
          Maybe you can post a video of the test run mentioned above as well as an EagleTree file of that. Especially interested in voltage/current/rpm of that bench try.
          regards,
          Manuel
          • vvviivvv
            • May 2009
            • 1079
            ill need help with the eagletree... working on it all while getting my car sorted
            • Prop-a-Gator
              • Feb 2012
              • 163
              What ever happened with this?
              Disclaimer: I hereby accept the potential loss of motor, ESC, entire boat, or credit rating, and forfeit all expectations of success.
              • vvviivvv
                • May 2009
                • 1079
                Just havnt had the time, the boat is at my other house (at my lake house) and quite frankly im scared to run it... the batteries not being looked after for a year, despite never being ran.. i will run it as soon as i go home, promise
