Closed loop cooling
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /Mono -
I don't know if this applies here or not but I thought I'd throw it out there. When I was running nitros I took a good sized ESC cooling plate and attached it to a small aluminum box the same size as the cooling plate. I made the box out of al. with a vented lid. I put a small block of dry ice in it and hooked it up in line with my raw water cooling system. It helped the engine maintain temp on the hotter days here in florida. I was also able to adjust the temp by changing the location of where I spliced it in line. the closer to the engine the more cooling the farther away the less. It worked good.Comment
"My opinion only (after attending close to twenty SAW's) :
The majority of SAW boats don't use cooling ; short runs make it pretty much a luxury.
Gilbert and Kevin's HPR is not a purpose-built SAW boat; they do run it for sport so their longer runtimes make the closed loop system appropriate.
Hyper cooling won't save an overstressed setup."
Thanks Tony, that will save me a lot of unecessary work. 105.932 MPH!!! Geez, how fast could they go with a pure SAW build???JIMJIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract SpecialistComment
Reason why not?
I don't get why people keep bringing this up.
You're working completely backwards by going to a closed loop system. You have an extremely large supply of cool water, the only reason to circulate the same water is if you were using it to heat something. You're ignoring the one advantage boats have and handicapping yourself.
Something you might want to consider if you haven't already:
If you use a tank to store your half gallon of water, consider using a series of dividers inside the tank with small holes drilled in the bottom. If you have no dividers and a decent mass of water, you may experience handling issues from the sloshing water.
I assume you are using ice water and no heatexchanger, as you obviously won't get a heat exchanger to cool the water better than lake temperature. The dry ice or alcohol ideas aren't bad. You could use a large water cooling plate mounted in an methanol bath or in dry ice to act as a heat exchanger. It's definitely over-complicated but I assume that's what you are going for.
Am hoping for real world experiences here, people.
Gd'ay Aussie Doc Wayne. Your work is very interesting. Exactly what type/brand of water pumps are you using? I need to know where to buy a couple. I'd like to duplicate your closed loop system to cool the ESC only in my 10S2P 56" Seagad SAW cat (pic above).
Im considering using dry ice & methanol in a +- quart, baffeled container. Is Jay "Fluid" correct: "Dry ice and alcohol risks over-cooling the ESC, causing breakage of parts and epoxy not designed for sub-zero temps."?My ESCs have no moving parts, so what's to break?
I will be running twin Castle Hydra ICE2 200 Amp escs, Twin Turnigy 240 Amp ESCs for backups if the Castles smoke.
The next SAW for me is in October in LA. Legg Lake temp will likely be mid to upper 70s, and is only 10' deep. Opinions please!JIM
Ok, here are a few thoughts on the valid comments so far.
1. methanol/alcohol in a boat filled with 'sparks' .. Hmm
2. if the dry ice cooled system was static ( no flow ) for a period, the water could freeze in line
3. overcooling is bad ? only if system is quench cooled.. a continuous flow is most appropriate before during and partially after a heat cycle.
4. pre-chilled water is an easier option here.. no need the logistically difficult dry ice option, nor the EPA ( Environmental Protection Agency) concerns over flammable/toxic liquids on some the reservoirs ..
We have ( I had to think hard here ) NO free water where we can run inside this state .. literally all the water is govt/developer owned and/or drinking reservoirs.
Tony, I look forward to a few detailed shots of the HPR.
WayneWayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
@ 36" H&M Maritmo twin1512/1800 6S1P 88mph @ 40" drag hydro#1 twin 5692 12S1P .....always for fun @Comment
It is a stupid idea, absolutely, if you want to be frank. It's an exercise in creating a problem for yourself, and then trying to find a solution to said problem. You made it clear in your prior post that you enjoyed over-complicating things, so with that in mind I ignored the fact that this may not be the best or easiest way of doing things, rather something different for you to try. I am aware that many of us will create things that are made to be interesting designs, but not neccesarily the most logical. It was with this in mind that I posted for the second time, attempting to be helpful, instead of just crapping on your idea. It is apparent now that the former was a mistake, and not welcome.
In terms of "real world experience", that's where my posts were derived. I wouldn't even comment in this thread if I didn't have the experience.
I leave you to your idea/design. Best of luck and good day sir.Comment
After reading many threads on cooling, this one included, I've come to realize that I'm uniquely unqualified to offer any valid empirically-based info. I do have lots of experience-based observations, however. One thing that disqualifies me from being able to contribute is the fact that ALL of my boats are rigged for oval, 2-lap, or SAWS (with the exception of offshore). My max runtime never exceeds 2 1/2 - 3 minutes except for offshore which is 4.5 minutes. All of my setups use "overkill" speedys with max headroom, and most boats have independent (dual) water pickups for the motor & speedy. I just installed a cooling fan on the endbell of a Spec-powered offshore cat as well. ( I know, not much circulation but better than nothing - NAMBA rules prevent re-insulating the 3-wire hotspot)
High performance sport running (with extended runtimes) is another story, and maximizing cooling isn't a bad idea , I'll give that. Using techniques that have been discussed here and in previous threads will definitely enhance reliability and prevent equipment failure from excessive heat buildup. But I'll still hold on to the concept that all the cooling in the world won't save a setup that generates undue heat buildup from overstressing the components. Which leads me to the thought that if cooling is a preventative measure designed to protect the equipment, why not (the way a LVC protects batteries) have thermal sensors on both the motor and speedy which feed a thermal cutoff circuit the way that some speedys "thermal" but extended to the motor as well. We already have temperature logging sensors-why not have them feed a protection circuit which shuts things down before the dreaded smoke escapes ?
I know why Kevin and Gilbert devoted so much attention to the cooling on their HPR - Some time ago they were running a high-volt Aeromarine Hydro which got a "little too hot" - it burnt to the waterline right in front of them; all that was salvaged was the rudder; @ 6K up in smoke !
Dr. Wayne, I applaud your efforts to add reliability to a 90+ mph 54" twin cat but (please don't take this the wrong way, I really respect your knowledge and aspirations) - keeping a boat on the water at 90+ mph may not consistantly result in runtimes long enough to get things into the high-temp danger zone
Last edited by properchopper; 05-12-2012, 10:52 PM.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /MonoComment
I enjoy OSE for it's wealth of knowledge from experienced and talented people, volunteering information to threads like this asking.
Assist is always appreciated.
Equally Ive learned the confusion of replies sometimes brings pearls of wisdom.
Perhaps the comprehension difficulty is deciding who knows, and who knows not.
Keith : thanks for your words, glad you added detail, pity you've left and unable to read this ..
Some areas we run boats have not the best quality water.
Our rivers have salt and sediment stirred up..ecoli and algae blooms an infrequent visitor the CBD waterways.. !
Our clubsite experience one or two closures a year due the quality.
A closedloop system would avail me of continuous flow and quality.
I once 'lost' a CMB101 head due corrosion&occlusion inside jacket !
So, without anymore ado... ideas with detail of closed loop cooling systems most appreciated !
Im here to play toy boats, not bicker over opinions.
Thx
WWayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
I'll get some more details of Kevin & Gilberts system next time I see them including photos. I do know that they fill the resevoir with iced water and IIRC use dual pumps. More when I see them. At Legg the water's fairly clean with the exception of those pesky duck and turtle particles.
duck.jpgLast edited by properchopper; 05-13-2012, 01:45 AM.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
A single tank with pump per side seems the norm, from photos shared .....
Thx
I have thought of this more than once, what about an insulated container that would hold about a litre of "liquid", have brass cooling lines permanently mounted through the center and freeze it before each run. The liquid in the closed system would pass thru the container cooling it and not getting "mixed" with it. You could use diluted anti freeze or similar in the closed system, and when you're done just take out the container, pull the lines off each end and refreeze it...................just a thought.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Packs work best when warmed through to a "hot blonde's body" temp of 37->40'c.
I see HC have LiPo cooling plates.. these introduce a temperature dynamic across the polymer which I assure you is bad for business.
Id prefer to use those as heat dissipators in a cooling loop system !
Tony's idea of thermal overload protection on battery/motor is a simple piece of electrckery, right up my alley.
This cat will run 2280s at 6Kw max . runtime 3->5 min at outside... calcs by batterys and ratings at hand
Planning 1000cc chilled coolantr fed to both via 2x 6Vdc pump capable 500ml.min feed under load.
Coolant cycled every 60 secs, give or take.. .
Will log delta temp in container first few runs and determine tank size requirements from there.
How hot is too hot ?
Will add thermostat to water bath. and set a failsafe throttle back .
Will set 50'c as the too hot spot.. unless someone suggests other wise ... ?
regs
Except for those 2 times when the castles self cremated, I dont overheated packs.
regs
W) Had to remind myself that my "shorter runtime" POV doesn't universally apply to the genpop of most runners. Looking forward to seeing what develops, particularly in the area of overheat monitoring of components coupled with slowdown/shutdown logic circuitry fed by thermal sensors which already exist from the likes of EagleTree. After all (to reiterate), much has been devoted to protecting batteries with LVC's so it seems the logical next step could be to extend this protection to the other vulnerable components.
That being said, I'll still champion the concept that addressing the causes of heat buildup is the place to start. Balancing the setup should be the initial starting point [although we all like to push harder and harder and often finding the "point of balance" involves going past it and replacing the heat-failed items; then backing off]. A multiple-sensor protection circuit should make finding the point of no return ( a good analogy, eh?) less expensive in the long run.
Please accept my apologies for deviating from the main subject of this thread (closed loop cooling concepts) but sometimes good ideas pop up where they might. Wiki : "heuristic"2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
