newbie build.....
  • smm_cbf
    • Mar 2008
    • 272
    newbie build.....
    finally got craxy maxx's scat cat 21, but didn't really like the setup so i changed it up alittle...what ya think?
    specs:
    -scat cat 21
    -bby hardware
    -plettenberg motor 12 cell
    -running 12 cells(dual 4500 batts.)
    -victory esc (rc hydros.com)
    -hitec servo
    -jr recever
    -jr digital radio
    test run will be on this saturday....see what happens i guess
    Last edited by smm_cbf; 04-13-2008, 09:37 PM. Reason: sounds better and gives more info
  • crazzy maxx
    • Dec 2007
    • 498
    i can just hardly try and look at this thing.
    nothing else to state
    snort pixi sticks=symptoms-:
    • ace028
      • Aug 2007
      • 952
      Looking nice man, but you might want to consider taking those tamyia plugs off and using deans or bullet connectors, Id hate to see ya drive it and have it stop in the middle of the lake cuz the plugs melted from too many amps, or something worse. Are you going to video your maiden run?
      Twin power =
      • smm_cbf
        • Mar 2008
        • 272
        im using pigtails with deans and tamiya connectors. i just got back from it first run and i totally fogot the camera.... everything went well, top speed on 12 cells was around 38 mph. handles great, i don't think it need water cooling, cause it didn't get to hot even on 12 cells, but im going to make a top with some air vents one u front and one in the rear , so air should be forced trough out the in side.
        • crazzy maxx
          • Dec 2007
          • 498
          got any action ashot yet???
          • SJFE
            • 4735
            Is that the amount of rudder stand off BBY recomends for the 21????? I look's like 4 or 5 inches to much IMO.
            • crazzy maxx
              • Dec 2007
              • 498
              thats what i said when i got it.
              • smm_cbf
                • Mar 2008
                • 272
                it turns really good with it. i replaced the traxxas with a hitec servo. last night i took the motor apart and replaced the 5 turn armater with a 3 turn. i hooked up the motor on my work bench and it is insane.....can't wait to have sitting in my cat. i was thinking doing water cooled and air cooled with air vents built on the hatch.
                • ace028
                  • Aug 2007
                  • 952
                  I think the water cooling will be your best bet. Air scoops might not be so great if it flips over.
                  Twin power =
                  • smm_cbf
                    • Mar 2008
                    • 272
                    heres a vid of a bench test with the new 3 turn armature. (warning, don't turn the volume up to much on your pc)
                    sounds pretty kick a$$ i think
                    Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
                    • smm_cbf
                      • Mar 2008
                      • 272
                      i have a question, im afraid the sparks coming out of the motor will burn the plasic hull so im going to lay a piece under the motor so the sparks don't screw up the hull, but i don't know what material to use, i was thinking so thick styrene, or plexiglass? any suggestions, thanks
                      • smm_cbf
                        • Mar 2008
                        • 272
                        started on the top, still have to design the vents. what ya think..
                        • crazzy maxx
                          • Dec 2007
                          • 498
                          i think you should design like a cock pit over where the motor hole it andput a vent on top of it. make it look like a racing cock pit
                          • smm_cbf
                            • Mar 2008
                            • 272
                            do you have any design type ideas? im having a hard time dsigning this top.
                            • crazzy maxx
                              • Dec 2007
                              • 498
                              some thing like this http://www.fastelectrics.com/hulls/elrayoxraymono.jpg over the hole...
