41" Osprey,is a T600 1400kv on 6s to small.
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1837
    I'm running the SF200 in the osprey, it should be able to burst around 5000W peak on 6s the SF 240 is double that.
    • martin
      • 2887
      The idea is to keep prices in check a bit which is why im sticking to 6s max & 180 - 200a esc with reasonable price motors but still have a reasonable performance, otherwise specs & prices just run away thats why im not interested in things like 5698 motors with very expensive esc & massive batteries that just add weight for just a small increase in speed. Martin.
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1837
        Well, the 4082 and SF200 will do you fine for sure. Just start with 445 prop ans see how you go.
        • Basstronics
          • Jun 2008
          • 2345
          Whats your guys opinions on a Little Screamers 650Kv Hurricane motor in the Osprey.
          I accidentally bought one!
          • nata2run
            customcfparts.com
            • Nov 2011
            • 1837
            Might be ok on 12s
            • Basstronics
              • Jun 2008
              • 2345
              Here is the sellers description:
              Designed to be the equivalent of a Zenoah G26 Gas motor for boats. This will push a 20lb boat upwards of 70mph on 10S with the same prop setup as a Gas boat.
              Description and specs below :
              Hi Guys,
              Yes the Littlescreamers Hurricane Brushless Waterjacketed Outrunner is now available!
              This Large Water Jacketed Outrunner was designed for big boats 40-90". It will perform well as a drop in HP replacement for the Weed Eater type gas boats. Designed as a racing motor to run against the gas and will be competing in the racing scene beginning 2010. Testing so far in a 40+ Race hydro we are running 65-68 MPH and completing 7+ laps on 10s. This is very exciting for a low cost alternative motor to be running with the $600 Modified gas motors and the Large Neu inrunners.
              KV650
              Shaft 8mm
              Watts 8,000+++++
              Im hoping this is big enough... lol, the specs and watts look promising.
              • Espresso
                • Jul 2011
                • 233
                Just curious where you found one? I swear they were discontinued but were selling for like $100 just prior. Normally they went for $150-160. It's a pretty mean motor if you got it for a good price.
