Speedfreak Gen2 Hydro Build
Boats looking good. My batteries went down the center and into the nose. The motor was mounted right behind the batteries. Everything gets mounted so you can get the cg 1 to 1.5" behind the sponson. You can probably get away with a more aggressive prop like a 560 or bigger since this is a hydro.
MarkComment
MarkComment
Just a few pics;
Arial view of steering linkage.
Installed the rubber boot on the extruded piece of CF tubing used for the rod.
I used milled fiberglass added to the epoxy and bonded the CF plate to the bottom of the hull and to the rail.
I used CF tubing for a ridged path for the steering rod.
Close up view of steering support.
Close up view of CF servo mount. I used a 3x4 piece of CF/K cloth, laid it down with the servo mount on top of it,
and poured the 2 part epoxy around it. It helped fill any gaps between the mount against the bottom of the hull.
GEDC2504.jpgComment
Last pics of the night
Last close up of the steering servo and CF mount.
Close up of drive line and support.
Same again,
Close up of the stainless cable saver.
Slightly closer,
GEDC2509.jpgComment
There is an opening to add oil but I may use it to apply grease instead. I have a small grease gun I use for my air powered tools at work that fits the hole perfect. I just need a way to work the grease down the tube instead of up
More pic's;
I've been trying to place the ESC in a accessible position and also add a little weight to the back end due to the large batteries, so I came up with a CF plate and mount it using the stuffing tube mount and the motor mount. I'm going to mount it using velcro straps and 2 inch wide velcro strip.
GEDC2535.jpgComment
