Anyone tried building one of these yet? Looking for a few pointers on set up as I'll be starting a build on one of these but converted to electric. Found some post's on the gasser sites but nothing on electric. Any help appreciated, :)
Speedfreak Gen2 Hydro Build
Tags: None -
Mark F may help2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /Mono -
Marks boat makes the lake look so much smaller. Beast is rightly named. I've seen this vid before and am awestruck each time I view it. Brutal power.Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco PowerComment
What I have so far
1 Castle 2028 780kv
2 10s 4500mah 40c lipo's for 9000 mah in 2p
1 x460 and 1 x462 props.
Strut and rudder
Turn fin
Motor mount
1/4 flex drive
I have almost everything to build it except for a few pieces of hardware. I will need brass tubing, collet, some cooler lines and most importantly, 1 Fightercat 400amp 16s ESC.Comment
Updated pic's;
Added CF plate reinforcement to transom
Rudder Placement
I use a dremel tip to start the holes
Then advance to the correct drill bit
Added CF/K mat to inboard floor between rail's
GEDC2270.jpgComment
I fab'd some motor mount brackets out of CF plate
and sandwiched them together into a 3 ply piece
bonded with 2 part epoxy from Illstreet composites.
The front and rear brackets are also tapped
and held together with 4mm cap head screw's
Brackets are installed on the rails
Used a clamp to hold in place while drilling holes for rail mount.
Used 4 3mm cap head bolts to secure the bracket to the rail
GEDC2330.jpgComment
Looks good so far John. Do you think you may have it in the water this season?Team Liquid DashComment
By the end of August anyway! I need to get the batt's and the ESC situated. This thing really cook's on 10s! You had a great Idea
Thanks for the opp to build this one
More pictures;
I made similar 3 ply mount's for the stuffing tube.
Another pic of the motor mount bracket's.
Stuffing tube mounted.
I used a drill bit to center the stuffing tube mount,
and set the angle of the tube itself.
I used the drill bit to mark my area for the entrance of the stuffing tube.
GEDC2336.jpgComment
And more pic's,
Finished drilling the opening holes.
Finished off the opening and placed the tube through the hull.
Bird's eye view.
Side view.
I cut a piece of CF/K to fit the opening and overlapped
one piece with another to close any gap.
GEDC2354.jpgComment
A few more;
Added cloth and 2 part epoxy to the opening.
Looking from the rear forward.
Bird's eye view of opening after setting up.
Interior view of cured epoxy.
I used some loose pieces of CF/K cloth to
add to the bottom of the hull opening.
GEDC2369.jpgComment
And a few more;
I poured 2 part epoxy into the opening pocket
created by the opening filler on the interior.
This is where I added the strands of CF/K fiber.
Cured stuffing tube opening.
Rear view of finished stuffing tube install.
Side view of finished product.
GEDC2373.jpgComment
Just a few more :)
I cut the .250 flex cable to length with a cut off wheel
in my dremel tool.
Installation of the flex. It lines up perfectly with the motor collet
indicating proper mounting of the tube and bracket.
Ariel view of cable installed.
I'm using a stainless cable saver from McMaster-Carr as
suggested by a fellow forum member.
I used vacuum caps to cover any exposed bolts or nuts
to prevent any damage to the 10s Lipo's.
GEDC2450.jpgComment
Just a couple more....really :)
I'm using an Octura x462 prop, currently unfinished, but soon to be :)
I used wire loom hold downs and screwed them
into the side's of the rails to hold the cooling tube's in place.
Working on the routing of the cooler tube's.
These should keep everything tidy :)
Nice an neat and no worries of rubbing through.
GEDC2449.jpgComment
