ill take pics tonight. This isnt a stinger. Its the speedmaster 21 strut with round bottom mounted on a Mean Machine.
Speedmaster 21 strut
Assuming the stuffing tube is running thru the entire length of the strut, there is nothing wrong with that picture. The strut bushing is supposed to "float".
Later,
MikeComment
Exactly. The SPD strut, unlike the AQ one in the picture, requires the stuffing tube to go all the way through the strut; then the bushing fits in the total length of the stuffing tube inside the strut. It IS supposed to "float" or rotate and will slide back and forth in the drive dog-to-strut gap.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Hmmm. Let me take a shot at it. Are you saying that the metal shaft (where it it does not flex) is to long too slide into the strut all the way? If so, there are different lengths of the solid part of the shaft available for different struts/stingers. Sorry if I just pushed you over the edge of the cliff and just missed the point of your problem...Comment
I can't think of any reason why you can't just add a piece of tubing the same size as your stuffing tube to extend it to the back of the strut. I've done this before with no ill effects.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
I always use a separate sleeve in struts or stingers for the Speedmaster bushes. By only taking the stuffing tube into the strut 1/4" or so the strut angle is easier to adjust.
Here's a pic of how I press the sleeve into the Strut. A smear of oil over the sleeve helps if it is a bit tight.Attached FilesSee the danger. THEN DO IT ANYWAY!!!
Here's a pic of how I press the sleeve into the Strut. A smear of oil over the sleeve helps if it is a bit tight.I'm with you on that; recently did a build just like that for more adjustability. Another way I've dealt with the situation is to ditch the sleeve bushing entirely and press in lead teflon bushings - less drag (in theory at least)
Here's a pic of how I press the sleeve into the Strut. A smear of oil over the sleeve helps if it is a bit tight.Comment
