Stupid ESC question
  • floatn turd
    • Oct 2011
    • 267
    Stupid ESC question
    I have always had ESC's with no BEC. I just bought this one from Fightercat. I would have to assume the "black" wire is for the BEC. My question is what kind of battery should I use & who sells them? As I have never dealt with a BEC. Is there anything I should know??
    Here is a pic. (yes I know its small)
    PS its the black wire at the top of the picture. and it "disconnects" in the middle of the wire, its got like a tiny little bullet connector.
    thanks
  • Diegoboy
    • Mar 2007
    • 7244
    The link doesn't work for non members.
    Since I can't see an image of the lead colors, typically the "middle" wire is the one you're looking for
    Here's a RX Battery
    Here's a RX pack for AA's
    • floatn turd
      • Oct 2011
      • 267
      I put a picture up, but my wire does not have the "connector" to plug into the RX
      I found a pic.
      08.jpg click for larger image
      Here are the specs:
      Intruducing the FighterCat Racing OEM Series 240a HV ESC!
      Now with FighterCat V2 BootLoader Firmware!
      This batch has the 8mm bullets directly on the PCB for optimum performance! Each bullet has been checked for soldering quality and includes the male mates in the package.
      This FighterCat LV 240a ESC comes with software license for programming and an optional USB adapter for ease of programming. Alternatively can be programmed via the Tx and by field programmer. Field Programmer is the simplest, fastest and most convenient. It works using the internal ESC BEC. Just plug in from the rx, set and go!
      Components are designed to handle 35 volts, FET's 40v. Realistically, 35 volts or 8s operating voltage. (8s preferred max)
      •Max Constant Current: 240a (in optimal conditions)
      •Max Current: TBA
      •BEC: 3.5a Switching BEC (Add a BEC Capacitor for large scale servos)
      •PWM: 8 KHz 16 KHz 32KHz
      •Input: 2 to 8s LiPo (8s preferred max)
      Programming options:
      •Battery Type, Number of cells/auto, LVC Voltage & Cutoff type
      •Power Limit Forward & Reverse, 25, 50, 75 & 100%
      •Throttle Curve, Logarithmecal, linear, exponential
      •Acceleration, Soft, Medium & hard
      •Timing in 1 degree increments 1-30 degrees (Timing MUST be properly set or will cause failure)
      •Delay time, .25S to 5S
      •Timing Monitor, on/off (timing monitor will beep the timing setting when plugging in the ESC)
      •Reverse, on/off (turns off brake too)
      IMPORTANT: Timing must be set prior to test/use. DO NOT RELY ON FACTORY DEFAULTS THIS IS NOT A PLUG AND PLAY ESC
      © 2011 FighterCat LLC - All rights reserved. Firmware & programming software developed & written in co-ordination with FighterCat Racing.
      Basic Programming Steps for advanced users;
      1.Install the Prolific USB drivers (as administrator)
      2.Note the Port in Device Manager
      3.Install the FighterCat PCS .exe
      4.Launch the FighterCat PCS .exe
      5.Indicate USB Port From Device Manager in the PCS
      6.Connect 3s lipo to the ESC and the Motor
      7.Connect the USB to the ESC
      8.Select the ESC type until you hear a beep
      9.Set each parameter, ESC will beep when set.
      10.No beep, no set... lol.
      Get the field programmer. It rocks. 15 seconds to set an ESC and be done.
      • properchopper
        rcgoatbuild@snotmail.com
        • 6968
        [ATTACH=CONFIG]69682[/ATTACH]
        thanks
        Hold everything ! Your SC HAS a built-in BEC. DONT use a Rx battery ! The "mystery wire" is an anti-spark wire with built-in resistor. If you're using a 4S setup, you wont need it.
        • floatn turd
          • Oct 2011
          • 267
          ahhhhhhh, and yes my set-up will be 4s thru 8s. So what do I hook that wire up too?
          P.S. How did that motor work out for you at the races? was my old motor a "big winner"?
          • properchopper
            • 6968
            I only run 4S setups, never had a spark problem. When you connect the 6s + batteries you'll get a bigger spark so the resistor prevents having a BIG spark which over time will erode the connectors.
            Here's what I think works :
            #1 : before connecting batteries, plug black resistor wire in your nose and comb your hair real fast.
            OR
            #2 : I really don't know. My guess is that you connect the loose end to the battery neg (it's black so I'd assume it goes to the neg). Connect red batt wire to red SC wire. Join resistor wire at the little connector. Connect red battery wire to SC.
            Remember, the FCR speedies MUST be programmed before use. If you have the field programmer, use it. If you have the USB thang, good luck. I just got three FCR speedies & can't for the life of me get my cormputer to cooperate.
            Motor & SC tested fine in one boat; now installed in my latest build . Race is in 22 days and counting. Seven boats in seven classes. Digestive anomolies have begun
            • runzwithsizorz
              • Jan 2009
              • 896
              Is the black, and red connector for the programmer? or some sort of by-pass for an RX battery pack? If the latter, I think that would be kinda neat, frees up a slot on receiver.
              Edit: a programmer would have to have 3 wires?
              • properchopper
                • 6968
                Just saw the picture. No idea about the black-red connector.
                • LiPo Power
                  DJI Drone Advanced Pilot
                  • May 2009
                  • 3186
                  Reg picture post # 3
                  Red and Black is the wire to power up the cooling fan that is installed on the top of ESC.
                  Black, single wire is antispark.....( 1.Connect red from battery to ESC, 2. Connect the antispark with black battery wire and than connect the main black from battery and ESC, that way there will be no spark, spark went via resistor installed inside of the small black wire)
                  Cheers
                  Robert
                  Canada
                  • LiPo Power
                    • May 2009
                    • 3186
                    Reg picture post # 3:
                    Black and red is for the built fan!!!!
                    Yes, programing wire would have 3 wires.....
                    Canada
                    • LiPo Power
                      • May 2009
                      • 3186
                      That wire is antispark!!!!
                      Cheers
                      Robert
                      thanks
                      Canada
                      • floatn turd
                        • Oct 2011
                        • 267
                        OR
                        Option #1 was a good one, funny S*#t... right there
                        • floatn turd
                          • Oct 2011
                          • 267
                          Cheers
                          Robert
                          Lipo thanks for the info, the mystery has been solved..
                          thanks again
                          • runzwithsizorz
                            • Jan 2009
                            • 896
                            Not all mysteries have been solved. Still can't figure out post #9. must be some sort of code, . I think we're to go to the Total Coast, meet up with big name at the China market, and for only 10, we can run long time.
                            • floatn turd
                              • Oct 2011
                              • 267
                              ya, his post was some "next level s*it" right there. I think he wants to meet at the designated "drop off" and pass the Micro-fish film............................... SHHHHH someones coming!!!!
