Need Advice Managing Castle 8mm Bulletts
    • 7673
    This has been good reading,I have a few 8's on the new 1717 35"DF.I think I'll try to stick to my 6.5 CC bullets.
    • AlanN
      • Mar 2008
      • 334
      I would try to lube them before any sanding. How about a dollop of dielectric grease (spelling?). WD40 or sim would probably get all over the plugs rendering Tonys girlie fingers to slip right off. :)!
      • DPeterson
        • 842
        Tony
        I was taught years ago to solder the esc directly to the motor wires on high amp set ups. Worked very well in intense high amp setups. Doesn't take much time at all to solder or de-solder for replacement. Eliminates alot of issues.
        See you in a few weeks.
        Doug
        Doug Peterson
        IMPBA 19993
        www.badgerboaters.com
        • properchopper
          • 6968
          Ok, OK Alan. So my girlie fingers slip off. No big deal except for those bruises on my forehead
          • properchopper
            • 6968
            Originally posted by DPeterson
            Tony
            Doug
            Right you are, Sir. Halfway through my 2-boat 8mm soldering extravaganza I had that same thought. I'm pretty sure it was a thought - I dimly remember what they feel like
            • detox
              • Jun 2008
              • 2318
              I like the looks of the Hobbyking 6mm connectors.
              http://www.hobbyking.com/hobbyking/s...idproduct=5281
              • carlcisneros
                • Jan 2010
                • 1218
                Those little 6MM HK connectors are Fraken TIGHT!!!!!!!!!!!!!!!!!!!!
                I used those on a couple new motors and ESC's for a retro-fit on a twin mono of mine.
                • steveo
                  • 1454
                  #23
                  well tony if your not going to swap out motors all the time hardwire them together, i never used a connector between my performance brushed motors ( i know they had a place to solder) and these were way lower amp draw applications than what your pulling and duration- its an option
                  • properchopper
                    • 6968
                    #24
                    I'm coming around to realizing that soldering motor & SC wires is a better option. It's just that the racer in me seems to hold on to the idea that connectors would make it easier to swap out frazzled speed controls between heats to stay in the race. Of course I'd need my spare SC's to have 8mm connectors installed which isn't the case as of now - looks like I jumped the gun with the 8's. Live and learn !
                    • properchopper
                      • 6968
                      #25
                      Test #1 with 8mm's
                      Back from the lake with the Cyberstorm rigged for P-Offshore. 3 min test with mild prop (boat needs to run 4 1/2 minutes minimum in offshore, thus mellow prop to keep current draw and mah consumption under control). 8's were barely warm. Next test will come soon with the IB34 rigged for P-Mono and a big wheel on the back pulling much more current. Will post results soon.
                      • JIM MARCUM
                        • Jun 2011
                        • 773
                        #26
                        Tony, thanks for starting this thread. I've had three trips down to the local lake with my Apparition and all three times the 5mm bullets desoldered. All 3 wires twice, and after reducing flex shaft drag, only one fryed on the last run. I was hesitant to go with 8mm bullets with the assumption that the relatively small guage motor wires would still heat up enough to desolder the connectors. I'll change to 8mm bullets & give it a try. Thanks bro. JIM
                        PS: Do you use teflon liners in your stuffing tube?
                        JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
                        • jcald2000
                          • May 2008
                          • 774
                          #27
                          The 8mm bullets will act as a heat sink and help keep the spec motor WIRES cooler, about 20 degrees.
                          • properchopper
                            • 6968
                            #28
                            Very interesting concept. I like it, makes sense.
                              • 7673
                              #29
                              I just got a bunch of 8mm from Ben at Fightercat.They are the nicest I've seen yet.They are large enough to grab.The others that came with my used mono have no "meat" to grab.I'll post a comparison photo.
                              • sundog
                                Platinum Card Member
                                • Feb 2009
                                • 878
                                #30
                                I'm sure that is a contributing factor, but IMHO the lower resistance (of the 8mm bullets) is the main reason they don't heat up as quickly as smaller connectors. I agree that soldering the wires is best, if that is suitable.
                                Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
