Just bought an HK Apparition, Who has/had one??
  • intenserapture
    • Jan 2012
    • 12
    #46
    I maidened my Apparition this weekend, it went really well.
    Needs some trimming, and messing around with some props.
    Where have people found the best cog on these?
    • floatn turd
      • Oct 2011
      • 267
      #47
      http://www.youtube.com/watch?v=DX6jzXTLRFM
      I'm not even to the point your at yet, but if you search under "HOTR" here on this site. There are tons of threads on builds of these and a lot of talk on COG on a bunch of different set-ups, but you will have to read thru a few threads to find the info, but there is a lot of it.
      • Drax21
        • Jul 2011
        • 1021
        #48
        My Apparition is a bit heavier as its re-enforced but I like it 50/50
        Mine didn't turn well until I raise the back end out of the water a little.
        Its a Twin 7XL batteries in front are 2x 4s 4000mah 35-70 c
        Everything that has a beginning, has an End
        • JIM MARCUM
          • Jun 2011
          • 773
          #49
          Drax21, Any problems running your twin Apparition with one ESC? Any advice? JIM
          JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
          • Alexgar
            • Aug 2009
            • 3534
            #50
            i disagree about the handling of this boat if you ask jesse j mine runs 60+ very stable and he was impressed to see my overpowered hull pull wheelies and pull so hard in the turns and cc2200 on 5s was a prop skater
            • rcboatmanwithkids2880
              • Aug 2008
              • 340
              #51
              Hi Guy's ,
              Before we get ourselves into a knot regarding the capabilities of the Apparition , we all need to do some research on what other members have accomplished ( I know I am guilty of this at times ) . Seem to remember a forum member about a year ago running 10S set - up in his , during his build he had a few Gurus that doubted this application & much worse his sense of adventure , after he built it , he also made a YouTube video to show us all what can be achieved by his initiative & positive forum advice - think it may have been Fightercat ( he da man when it comes to Apparition / Genisis )
              Brad
              Oz
              Roy Cooper's www.fastonwater.co.uk - Where Brittish Raceboat History Comes To Life !!!
              • Drax21
                • Jul 2011
                • 1021
                #52
                Hi Jim, you are not the first person to ask this question and sadly I can't answer it. It is actual 2x Himodel 200amp escs joined together with custom watercooling through the middle and a layer of liquitape covering the escs. Both the motors have their own water cooling and the rudder provides the cooling for the escs.
                • shannon87
                  • 222
                  #53
                  its the same for me im running a leopard 4074 2000 kv and changing to a swordfish esc so i dont have to mount it so far up under infront of the motor and gunna get an m545 or similar but it wah wahs like the geico and doesnt seem to get its power down but i think it has alot to do with the stock prop lol not biting coz it cavititates then screams off but the wah wah is annoying lol and makes it kinda look like it hasnt got all the power it has lol the strut is neutral how far should i have the batteries placed from the motor mount tho its currently stripped besides the motor mount waitin for goodies from kintec and batteries from hk and prop from a local supplier lol coz the batteries that came with it are only 20 c which alos would be contributing to the lack of power lol and im not gunna run it till i get those things as i dont want low amp lipos burning up my boat lol
                  • Drax21
                    • Jul 2011
                    • 1021
                    #54
                    Yeah, definitely replace the stock prop. Do you have a vid?
                    • intenserapture
                      • Jan 2012
                      • 12
                      #55
                      [ATTACH=CONFIG]68824[/ATTACH]
                      50/50, interesting. Reading the 30pager hotr thread some suggest the cog at around 8-9inch from the back of the sponson, mine was running with the cog much further forward than that. Next run I will balance it back there and see what difference it makes, also thinking of a x442 prop instead of the x440.
                      • Drax21
                        • Jul 2011
                        • 1021
                        #56
                        Yeah I'm technically not correct if you go by measurement of the whole 32". I give myself 25" of play room, the rest I stuffed flotation noodle in. The COG without batteries in is 9.5inches with batteries it becomes 13 inches. The batteries keep the front down enough at high speed but the stinger angle is parallel to the hull forcing it slightly down in the water plus it weighs more at the back because of several layers of fiberglass and the hardware. With the 4074 XL twins it was a very difficult hull to balance. Originally I had 4x 2s 5000mah batteries. 2 at the back and 2 at the front but every turn was so unstable because of too much weight at the back. I hope to get a video of it soon. Its very fast! My last vid I got flipped it at 55MPH 3/5 throttle with the 4 batteries.
                        • JIM MARCUM
                          • Jun 2011
                          • 773
                          #57
                          Drax21, thanks for the info. Love to see a video when you ger her finished. JIM
                          • Drax21
                            • Jul 2011
                            • 1021
                            #58
                            Will make sure I get the vid next time. Sometimes my camera crew are occupied I went to the lake the other day and thought it would be too rough for the Apparition. When I got their the wind had died off but I had only brought my mono .... I got to wait for the sunshine here in the UK. Hopefully Friday!
                            • shannon87
                              • 222
                              #59
                              to drax yer im gunna order a prop off here as soon as it comes back into stock and i did have vids on my phone till i dropped it last week after one to many drinks had a bad habit of sitting it in my top pocket at work and not buttoning the pocket but as soon as i get it rebuilt ill get a vid goin should be better on my new fone anyway i definately miss running the boat.
                              And also just checked out floatns last vid mine ran very simliar to that same sort of speed and bouncing like that if that gives any idea on how it ran
                              • Turbo Dan-O
                                • Feb 2011
                                • 292
                                #60
                                Here is one of my favorite boat videos. The 32'' hull on 9s! These hulls will fly!http://www.youtube.com/watch?v=g4Dwl...eature=related
                                Pursuit: T-180, TP 4060/1620kv. Genesis: T-180, GoolRC 2000kv. UL-1: Bone stock. MHZ Tsunami: Full tilt SAW project!
