Any guys run gas here???
MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169 -
No sir, that's a Titan 40 setup for P mono. Here is another vid. Titan 29, 40 and two Tritons. http://www.rcuvideos.com/item/BV4ZFZVF9YYVKWSC
The Caseman should have been called on that little move at the end.
DougMODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169Comment
P mono refers to the NAMBA classification of Fast Electric boats. NAMBA classifies boats based on power, actually nominal voltage.
Here they are:
D. CLASS SPECIFICATIONS
1. POWER SPECIFICATIONS
a) The following motor and cell configurations will be considered official for
electric racing in NAMBA:
M-2: A single .05 motor with brushes, any endbell, ferrite magnets.
Power Limits: 1-4 Ni-chemistry cells are permitted.
N-1: Any ROAR-approved stock .05 motor as defined by current ROAR
parameters. Power Limits: 1-6 Ni-chemistry cells are permitted.
N-2: Any single motor, any endbell, bearings, and magnets. Power
Limits: 7.5 Volts maximum, any chemistry. Maximum of 2 packs
in parallel. Maximum capacity of 10,000 mAh.
O: Any amount and/or size of motors, any endbell, bearings, and
magnets. Power Limits: 7.6 to 10 Volts nominal, any chemistry.
Maximum of 2 packs in parallel. Maximum capacity of 10,000
mAh.
P: Any amount and/or size of motors, any endbell, bearings, and
magnets. Power Limits: 10.1 to 15 Volts nominal, any chemistry.
mAh.
Q :Any amount and/or size of motors, any endbell, bearings, and
magnets. Power Limits: 15.1 to 22.5 Volts nominal, any chemistry.
mAh.
S: Any amount and/or size of motors, any endbell, bearings, and
magnets. Power Limits: 22.6 to 30 Volts nominal, any chemistry.
No limit on paralleling of packs. Maximum capacity of 12,000
mAh.
T: Any amount and/or size of motors, any endbell, bearings, and
magnets. Power Limits: 30.1 to 40 Volts nominal, any chemistry.
mAh.
b) All of the above classes may be further divided into various hull types. For
specifications on these hull types see Section 11. Other specialty classes may
be added from time to time.
Hope that helps.Don't get me started
Namba Shmamba
Doug
MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169Comment
