new wires
  • byron
    • Dec 2010
    • 65
    new wires
    hi guys i want to install 10 ga wires to a turnagy 120 esc . i tried to melt the solder hoping the wires would come off but they don't ! how are they attached besides solder?
    any help would be great,
    thanks
  • jamespl
    • 742
    Why do you want bigger wires on t120? Surely turnigy have made it to handle 120 amps.
    • byron
      • Dec 2010
      • 65
      there too short ,so i thought if i make them longer i should go up one size of wire. the esc is 12 ga
      • Darin Jordan
        • 8335
        Byron,
        I would just install "jumper" wires... similar to what I've done here:
        http://forums.offshoreelectrics.com/...099#post281099
        Darin E. Jordan - Renton, WA
        • byron
          • Dec 2010
          • 65
          thanks for the pic darin that perfect .
          • Darin Jordan
            • 8335
            No problem. These ones are longer than you'd likely want/need, but you get the idea. You can use much larger wire for these, and then you'll negate any appreciable voltage losses due to added resistance. Makes it much easier to swap out ESCs and Motors...
            • byron
              • Dec 2010
              • 65
              thanks again , one last question about the esc . witch of the three wires on the esc go to the motor wires . esc wires are all the same blue colour labeled a ,b ,c , the motor (UL1) yellow ,black ,red ?
              cheers
              • jamespl
                • 742
                Just plug them in if it runs backwards just change round any 2 wires.
                • longballlumber
                  • 3132
                  Sounds your using a CAR ESC rather than a watercooled MARINE ESC... Do you have a picture?
                  • byron
                    • Dec 2010
                    • 65
                    no pics but it is a marine turnigy 120 that is water cooled
                    http://www.hobbyking.com/hobbyking/s..._Boat_ESC.html
                    • longballlumber
                      • 3132
                      ummmm... that is funny. Typically the ABC labeling is for sensord contollers and motors. I am not sure why they would put that on a marine contoller.
                      • Alexgar
                        • Aug 2009
                        • 3534
                        i couldnt melt the solder on my t180 either with an 80 watt iron i thing they are epoxy coated or something or they use high temp solder
                        • byron
                          • Dec 2010
                          • 65
                          thanks for all the help guys and merry x mas
                          • ray schrauwen
                            • 9472
                            It is good high temp solder.
                            On a side note I was able to remove the wires from a SF/Hifei 120 esc and successfully added 10G wires, 2 sets for 2P. It was pretty easy if you are experienced if not, you my melt parts with an 80W iron easy.
                            Glad you have it worked out.
                            Nortavlag Bulc
