Outboard water cooling questions???
  • jasoncyclone
    • Jun 2011
    • 475
    I just bought my first tunnel hull 'cobra' and am looking for a picture of how to run the cooling system with the OS outboard setup? There are 3 nipples on the outboard? I just don't want to burn up anything. Thanks Jason
    Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!
  • HOTWATER
    • Nov 2008
    • 2323
    "Will race for cookies!"
    IMPBA D12
    My Gallery: http://forums.offshoreelectrics.com/album.php?u=1738
    • LiPo Power
      DJI Drone Advanced Pilot
      • May 2009
      • 3186
      May I please ask what is the purpose of this blue line and how it works?
      Robert
      Canada
      • HOTWATER
        • Nov 2008
        • 2323
        Hey Robert, the "blue" line is the oil line...the blue color is just residue from the flex grease that gets thrown in there. I pull that line off from the upper nipple and simply fill the line with 3 n 1 oil before each run to keep the flex lubed ( I also grease the flex itself ). You can also use Marvel Mystery oil and STP like Brian Buaas uses...
        IMPBA D12
        • LiPo Power
          • May 2009
          • 3186
          I see.... It make sense now...
          One more quastion. I see you have very nicely done conversion adapter....
          Where did you get it from? What prop are you spinning with this Ul-1 motor?
          Chrres
          Robert
          Canada
          • HOTWATER
            • Nov 2008
            • 2323
            That is a conversion made by Kris Flynn...he is on this board. Not sure if he is making any more of them, but you could ask. BTW, his O/B flex's that he also makes are second to none...very well made!
            IMPBA D12
            • LiPo Power
              • May 2009
              • 3186
              That is what I was thinking....
              I have one kit on the go from Kris with motor coolet and flexshaft....
              Takes forever to get staff here in Canada from Australia....
              Cheers
              Robert
              PS
              What prop are you spinnig?
              Canada
              • HOTWATER
                • Nov 2008
                • 2323
                Cheers
                Robert
                PS
                I am currently using a modded 42X55 prop.........
                IMPBA D12
                • egneg
                  • 4670
                  I have to agree about the conversion from Kris. This is my setup, I used a nitro fuel filter for the oil reservoir.
                  IMPBA 20481S D-12
                  • LiPo Power
                    • May 2009
                    • 3186
                    Cool, so gravity will push the oil down to both pipes....
                    [ATTACH=CONFIG]64904[/ATTACH]
                    Canada
                    • egneg
                      • 4670
                      Yes, I got the idea from some long time nitro racers.
                      IMPBA 20481S D-12
