The shelve life on the 603,638 & 648 is 2 years all the bottles are dated. Problem is if a supplier has had it sat on their shelves for some time thats costing you the end user, Ive bought it where its been on the shelve for 6-9 months so omly got just over a year before the date is up. I allways now ask the date on the bottle before i buy now. I spoke to Loctite about how crutual these dates are & they recomend not to exceed these dates as the bond deteriates if it past its date. Martin.
Question about Loctite for Flex shafts
For bonding into the stub shaft with Loctite, sanding the cable is definately not required. These products are designed to bond very smooth surfaces together, sanding only increases the gap and reduces the contact areas of the two surfaces.
I could not find "Super Clean 7061" on the Henkel website, no idea what it is. Surface prep products like 7471 and 7649 substantially reduce the strength of the Loctite bond with metal. Loctite 603 is oil tolerant making it the "best" product for the cable end going into the coupler.
.Comment
Instead of soldering the coupling end of the flex you can use 603 to help the flex from unravelling or crushing, put 603 where you would normally put solder. The 603 will penetrate into the flex, wipe of the excess 603 from the surface & let dry. You still need to degrease the flex as you would if soldering, but 603 is oil tolerant as well.Comment
I'm glad this post was dug up, great info !"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert EinsteinComment
Keep the Locktite in the fridge when not in use, it keeps better BUT, let it come to room temp before using again.Nortavlag Bulc
