TP power motors
  • 08gtrking
    • 91
    TP power motors
    Any one bought one yet? , the reason i ask is because idk whether to get that or a leopard motor.
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3480
    Yes, I have run a couple of them. I like the open air design and the smooth countersunk can screws.
    The ones I demo'd had the Japanese high speed bearings.
    I don't have the equipment to do a side by side comparison, but they ran as I would expect a 4082 size motor to run.
    I can get some photos side by side if you like.
    • 08gtrking
      • 91
      Thanks for your input fightercat
      • megalops
        Fast Electric Freak
        • Aug 2011
        • 249
        08gtrKing did you get one of the TP Power motors? I am also looking for that class/size motor.
        "If you can't win - Wreck someone who can!"
        • 08gtrking
          • 91
          yes i ordered one of the 4050 size , i will have a review up on fightercat`s web site in a couple weeks when i finish my boat
          • 6BOOST
            • Sep 2011
            • 286
            I have 2 each of the TP 5660's and 4060 size ones, I also have the leopard and turnigy version of the 4082, and leopard 5692, so will compare all 3 at some stage in the next few months.
            6BOOST
            6boost Turbo Manifolds, Australia's number 1 turbo kit specialist and manufacturer
            • lenny
              • Sep 2010
              • 4294
              Good to know.
              ? ONLY IF THEY WORK
              • megalops
                Fast Electric Freak
                • Aug 2011
                • 249
                6BOOST - Thats awesome, cant wait to see the comparisons. Any insight into which motor into which motor(s) are better is greatly appreciated. Unfortunatly I'm going to purchase something very soon.
                • Drax21
                  • Jul 2011
                  • 1021
                  I am currently running a 1515 2200kv but going slightly bigger would interest me. Looking at the 4082 2200kv version.
                  Everything that has a beginning, has an End
                    • 7673
                    A CC 1515 is 4086.
                    • Drax21
                      • Jul 2011
                      • 1021
                      Originally posted by srislash
                      A CC 1515 is 4086.
                      Neu-Castle 1515 2200kv - Motor Diameter: 39.98mm 41.78mm with fins
                      Motor Length: 75.18mm
                      It's slightly bigger than a 4074 Leopard
                        • 7673
                        Sorry man,my BAD.I grabbed a 1717 off the shelf.I stand corrected.I just grabbed a green can.4
                        I'm running twin TP 4082's in my Shocker,1810kv's.All good so far with 447's.
                        • ray schrauwen
                          • 9471
                          Can size means almost NOTHING when comparing these motors. You need to look inside and see how the stack is wound, the stacks actual length inside the can and the actual length or the magnet rotor.
                          Be careful you could compare apples to oranges without even knowing it.
                          Nortavlag Bulc
                          • Drax21
                            • Jul 2011
                            • 1021
                            Yeah I need someone who already has one to show me the insides.
                            • ray schrauwen
                              • 9471
                              The TP power 2180kv 4082 has windings that stop short of the rear end bell by approx. 1/4" - 3/8". I don't know about a Leo 4082??
                              This TP motor has no front air vent holes and I may drill them out after I remove the front plate.
                              TP power motors, at least the 5692's I have also have windings that stop short of the rear end bell, maybe up to 1/2".
                              The 56mm diameter motors have 16 segment stators vs Leo with 12 steps. TP motors appear to have a much tighter wind of field coils compared to what I have seen inside leo 4074's and Leo 56mm diameter motors.
                              If the stators are wound tighter and wound better you may not need as much length in stator but, I'm guessing on that.
                              The magnet wire is of a different source I would say also being darker (maybe because of thicker enamel coating or different enamel colour coating???).
                              So far until the ice melts, I won't know much more.
                              Nortavlag Bulc
