Square drive adapter for 5mm motor shaft for OB
  • LuckyDuc
    Team Ducati Racing
    • Dec 2008
    • 989
    I have been using the Hyperperformance collet for my UL-1 motor to square drive in my OS lower unit, but it seems a bit too soft. The drive cable spins just enough in it to get stuck in it. Does anyone else make a collect for this made from stronger aluminum or possibly steel?
  • kendt
    • Jul 2011
    • 557
    I am currently trying to figure one out as well. I wondered if a straight coupler with set screws on opposite sides would work or a regular style collet reversed so the set screws clamp the square end and the collet end clamps around the motor shaft. Not sure if either option would work without adjusting the space between the motor and lwr unit.
    • marko500
      • Aug 2008
      • 861
      I'm running into the same thing. I also was thinking about how to use a collet. I think I read somewhere about putting some Loctite into the coupler and about someone making shafts with a little larger square on one end that fit the coupler better. Mine jams but has not slipped yet so I've just been living with it.
      Mark
      • LuckyDuc
        Team Ducati Racing
        • Dec 2008
        • 989
        I was living with mine also, but it broke the shaft right at the coupler during my the last heat race. I think it broke because it wasn't free floating any more.
        If it had not been for a fellow racer having a spare flex shaft (Mike Ball), I would have been out of that class for the rest of the day.
        • HTVboats
          • Jun 2011
          • 803
          You could solder the tip of the square cable or tap a couple set srews in the aluminum coupler. Knock on wood we have put a lot of laps and test sesions with spec and larger up to 4082 motors on the OS lower and have not seen a failure yet. I guess you also could consider anodizing the coupler which would harden the surface. Cables break from use as long as it doesn't become a pattern.
          Mic
          Mic Halbrehder
          IMPBA 8656
          NAMBA 1414
          • carlcisneros
            • Jan 2010
            • 1218
            I have done what Mic has in soldering the tips of the squared cable. works pretty good.
            • LuckyDuc
              Team Ducati Racing
              • Dec 2008
              • 989
              I'll try the solder route on my spare. Thanks!
              • bigwaveohs
                • May 2009
                • 535
                Are you using the OS flex cable? The K&B flex cable is a little larger and a better fit in the HP collet. You will need to sand down the other square end a little bit to fit in the OS stub shaft, but it's a better setup with the K&B flex cable and won't spin in the collet.
                JMHO,
                Pete
                I let the dogs out...
                • longballlumber
                  • 3132
                  Hey Sean,
                  I have been using the square drive collet made by Ray Fuller and the same OS brand flex shaft for 2 full season now with no issues. I am no tunnel expert, but I would bet they want that flex shaft floating for a reason. Why? I am not sure.
                  • Kris Flynn
                    #2 Bench Racer
                    • 229
                    The couplers from Ray Fuller are the ones made by REK machining. They are what I use in my adaptor kits.
                    Some guys have bought flex shafts from me that have a square on 1 end to have a snug fit in the Hyperformance collet and smaller on the other end to have a snug fit in the OS prop shaft assembly
                    • LuckyDuc
                      Team Ducati Racing
                      • Dec 2008
                      • 989
                      I couldn't find a link for the Fuller/REK coupler. Fuller fast EL seems to be an Ebay only store now with no reference to the coupler.
                      • longballlumber
                        • 3132
                        Yeah... I looked yesterday and couldn't find one either. Maby Kris Flynn can help with getting you one. I also know that Kris is "the guy" when it comes to spare shafts. Maybe he has couplers too.
                        Later,
                        Mike
                        • properchopper
                          • 6968
                          I bought three of these shafts. One to use & two spares . The spares are getting lonely in my parts box since the one in use just keeps working, working.
                          • LuckyDuc
                            Team Ducati Racing
                            • Dec 2008
                            • 989
                            Hey Tony,
                            Are you running it in an OS lower unit?
                            Mr Flynn,
                            I would like to get the REK coupler with two of your flex cables to use in my OS lower unit. Please let me know what you need from me to make this happen. Thanks!
                            Sean
                            • properchopper
                              • 6968
                              Hey Tony,
                              Mr Flynn,
                              Sean
                              Sean, yes I am; the one I got from Mike L. In fact it's holding up just fine with a (play) 9XL in my heavyish 30" Herb Stewart hull.
