What speeds can a Mean Machine handle?????
  • millzee
    Ozzie Bloke
    • Nov 2010
    • 1092
    I'd like to know what sort of speed I should be able to get out of the MM, taking all the different set up's out of the question. I don't know what you guy's get out of yours and would like some goals to try to achieve. Is there a speed that too much?? I want to be able to set my boat up so she'll run a little more stable and still have good speed but I don't know what to shoot for.
    "Gimmy Toyz for FUN"
  • Rumdog
    • 6453
    That 1717 is just too much for your MM. You wont be able to put a big enough prop on that boat to take advantage of it's power. Also, that plus 6s2p is one heavy little cat. I ran my sprintcat .20/.40 (same bottom as the mm) With a CC/Neu 1518 on 5s2p and a x645, x447, and x548 and that boat was right around 60 mph and turned on a dime.
    One other thing you want to do is make sure the strut bottom is at least 1/4" above the sponson bottoms for a start. Moving up a little at a time from there.
    • millzee
      Ozzie Bloke
      • Nov 2010
      • 1092
      do think it'd be worth me trying out the 1515 2200kv on 4s2p with maybe a X445 / x447 or should I maybe look at getting another motor, say a 4082 or something similar?
      I have plenty of 4s and 6s I'd like to stick with
      • Rumdog
        • 6453
        The 1515 would be great in that boat. Go with the x445 and she should move out real nice.
        • millzee
          Ozzie Bloke
          • Nov 2010
          • 1092
          thanks man, I'll swap it out and give it burl next chance I get. If all goes well, I'll buy another to replace the one I'll be pinching out of my titan.
          I appreciate the advice
          • dana
            Banned
            • Mar 2010
            • 3573
            Try m445 instead with 1515
            • millzee
              Ozzie Bloke
              • Nov 2010
              • 1092
              thanks man, I have an m445 with the 1515 so I'll give it a run as soon as I get the chance. The lepard 4074 2200kv is about the same as a 1515 isn't it???
              • millzee
                Ozzie Bloke
                • Nov 2010
                • 1092
                I see steve has the 2000kv 4074 with cooling can and 180amp esc, would this 2000kv on 4s be a good match for it??
                • dana
                  Banned
                  • Mar 2010
                  • 3573
                  1515 very similar. I run leopard 2200 on 4s and get 50mph steady with m445.
                  • dana
                    Banned
                    • Mar 2010
                    • 3573
                    2000 be good on 4s, but 2200 be better
                    • millzee
                      Ozzie Bloke
                      • Nov 2010
                      • 1092
                      cool, I'll just buy them separate.
                      • D&D
                        • Aug 2009
                        • 185
                        I run the Nue 1515.1Y (2200) on 4S2P, but I run much smaller props, such as, 440-3 and the Y537. The boat runs 57 to a high of 58.5mph, but I don't feel the boat is good at those speeds for heat racing. My boat currently holds the IMPBA one-third mile Heat Trails record for P Tunnel Inboard, but I pushed the batteries way forward and I would guess that the boat was in the 52 - 55MPH range or slower. I think you will love the hull and enjoy the fact that you can change trim for speed or handling and have a lot of fun. Good Luck!
                        • dana
                          Banned
                          • Mar 2010
                          • 3573
                          Interesting, I've been meaning to try the x440/3. I'm gonna try it next
                          • millzee
                            Ozzie Bloke
                            • Nov 2010
                            • 1092
                            Thanks for the great advice
                            • Rich
                              • Jan 2008
                              • 551
                              Check out this thread, lots of info! http://forums.offshoreelectrics.com/...+machine+sport
                              24 R/C vehicles and still counting...What budget?
