I'd like to know what sort of speed I should be able to get out of the MM, taking all the different set up's out of the question. I don't know what you guy's get out of yours and would like some goals to try to achieve. Is there a speed that too much?? I want to be able to set my boat up so she'll run a little more stable and still have good speed but I don't know what to shoot for.
What speeds can a Mean Machine handle?????
Tags: None -
That 1717 is just too much for your MM. You wont be able to put a big enough prop on that boat to take advantage of it's power. Also, that plus 6s2p is one heavy little cat. I ran my sprintcat .20/.40 (same bottom as the mm) With a CC/Neu 1518 on 5s2p and a x645, x447, and x548 and that boat was right around 60 mph and turned on a dime.
One other thing you want to do is make sure the strut bottom is at least 1/4" above the sponson bottoms for a start. Moving up a little at a time from there. -
do think it'd be worth me trying out the 1515 2200kv on 4s2p with maybe a X445 / x447 or should I maybe look at getting another motor, say a 4082 or something similar?
I have plenty of 4s and 6s I'd like to stick withComment
thanks man, I'll swap it out and give it burl next chance I get. If all goes well, I'll buy another to replace the one I'll be pinching out of my titan.
I appreciate the adviceComment
thanks man, I have an m445 with the 1515 so I'll give it a run as soon as I get the chance. The lepard 4074 2200kv is about the same as a 1515 isn't it???Comment
I see steve has the 2000kv 4074 with cooling can and 180amp esc, would this 2000kv on 4s be a good match for it??Comment
cool, I'll just buy them separate.Comment
I run the Nue 1515.1Y (2200) on 4S2P, but I run much smaller props, such as, 440-3 and the Y537. The boat runs 57 to a high of 58.5mph, but I don't feel the boat is good at those speeds for heat racing. My boat currently holds the IMPBA one-third mile Heat Trails record for P Tunnel Inboard, but I pushed the batteries way forward and I would guess that the boat was in the 52 - 55MPH range or slower. I think you will love the hull and enjoy the fact that you can change trim for speed or handling and have a lot of fun. Good Luck!Comment
Check out this thread, lots of info! http://forums.offshoreelectrics.com/...+machine+sport24 R/C vehicles and still counting...What budget?Comment
