CEN Baja boss upgrades - motor
  • Make-a-Wake
    FE Rules!
    • 5557
    The amp rating is how many amps it can feed the motor.............your setup, hull, prop, motor size, kv etc..........will dictate what the motor tries to pull, so you need to have a logical setup and an ESC that will cover it by at least 50% more.
    • Shelbie67
      • Aug 2011
      • 135
      How do I calculate this? Will a 120 be ok? Was thinking of the leopard 3674 @ 2200 kv with the swordfish 120amp Esc. I also need a prop recommendation.....cost seems to be ok with that motor and Esc.....possibly gonna just go 4s lipo batteries
      • znus
        Broke, as usual
        • Jun 2011
        • 120
        Start with something 38 mm:ish, check your temps after 1-2 minutes of running. If everything still is cool, try a 40 mm, check temps after 1-2 minutes of running etc. etc
        I run a 3674 @ 2800 kv on 3s with a 437/3 (3-blade) and it's definitely on the hot side. Speed is about 42 mph
        25" Arrowana with Etti 2970 3300kV. RCMK Flying Cat with twin HOR Outboards. 2 x SSS 4092 2140kV. Faluga 45" with Leo 56110 620 kv on 12s.
        • Shelbie67
          • Aug 2011
          • 135
          So I have a bit of a problem....I went to pull my boat out from storage and it is gone and no where to be found.
          So now I am in the market for a new boat
          Gas or electric? Lol
          • Racer944
            • Jun 2011
            • 51
            You might want to look into the Proboat Impulse 31 if your looking for a mono around 30". Very nicely built and decent speed out of the box with good hardware and running gear.
            Cheers;
            Eric
