CEN Baja boss upgrades - motor
  • Shelbie67
    • Aug 2011
    • 135
    What is a good motor and Esc to run with this boat? I basically want to make this as awesome as possible.
    Is brushless the way to go? I don't want to go extreme with prices....I'm looking for a good bang for your buck combo or just above if that makes sense.
  • Diegoboy
    • Mar 2007
    • 7244
    Feigao 10L (2458kv)
    Swordfish 120A
    Turn Fins
    • Make-a-Wake
      FE Rules!
      • 5557
      3s........4s...................?
      • Diegoboy
        • Mar 2007
        • 7244
        3S, for the sake of cost
        • Shelbie67
          • Aug 2011
          • 135
          540 10L 2,458 RPM / Volt 5mm Shaft (3)
          What does the "10L" mean and why should I go with that over a 9 or 11? Just want to understand, any other motor suggestions?
          And 3s and 4s...I know that is in regards to LiPo batteries, but what does 3s mean? I appreciate all of the help from everyone!
          Lastly what's a good battery charger that won't break the bank?
          • Shelbie67
            • Aug 2011
            • 135
            On the swordfish, is that a simple plug and play?
            • Shelbie67
              • Aug 2011
              • 135
              Feigao 540 - 10XL will that work? Found a used one on here? Is it a better motor (power)?
              • Diegoboy
                • Mar 2007
                • 7244
                10L = number of winds & length of the motor can. It's a "L"ong motor and the 10 wind gives it the 2,458 RPM's per volt.
                3S = 11.1V lipo / 4S = 14.8V lipo. one lipo cell is 3.7V so if you have a 3S (three cell) 3.7 x 3 = 11.1V
                3S x 10L (11.1V x 2,458 RPM's per volt) = 27,300 RPM's
                If you want 4S (more common) use a lower KV motor than the 2,458kv.
                • Diegoboy
                  • Mar 2007
                  • 7244
                  The XL will have more torque to swing a bigger prop than the L.
                  10XL = 1,668Kv
                  4S(14.8v) x 1668Kv = 24,700 RPM
                  • Shelbie67
                    • Aug 2011
                    • 135
                    What about the Leopard 3674 or the 4074 at 2200kv?
                    • Make-a-Wake
                      FE Rules!
                      • 5557
                      You keep suggesting larger and larger motors which will all obviously work. That hull is not made for huge speed, just keep it in the mid to high 30's and you will enjoy it. That boat will do fine with any motor 3656 or larger............... I had a Cen aquajet a while back that i had a Feigao 13L in and ran it on 4s.........it was all the hull wanted.
                      • Shelbie67
                        • Aug 2011
                        • 135
                        I wasn't sure what I was posting which is why I made the post to get the proper feedback.......what does the 2200kv mean?
                        • 1truckerdan
                          • Aug 2011
                          • 329
                          kv is the rpm of the motor per volt ...4s lipo= 14.8 v X 2200kv =32,560 rpms.
                          Daniel
                          When you know it all.......you never will learn anything new
                          • Make-a-Wake
                            FE Rules!
                            • 5557
                            2200kv is rpm's per volt of input...........10 volts = 22,000 rpms. Target range for a 'sport boat' is around 22-26,000 rpms. Racing boats up to around 32,000, and SAW boats 35,000+. That is why Diego offered the 10L on 3s as a suggestion. Personlly i like 4s and 1800-2200kv for my boats in the 26-32" range. Keep askin' questions..................i did for a long time, and still do.
                            • Shelbie67
                              • Aug 2011
                              • 135
                              First, I want to say that this is a great and friendly forum, and I appreciate all of the feedback.
                              What is the difference with the amps on an Esc mean......is a 180amp better than a 120? Or is it setup related?
