Flex shaft question
  • JimClark
    • 5907
    Flex shaft question
    Bought a flex shaft on the b&S forum and it looks new but was trying to identify the maker. Doesn't look like the typical octura cable I have seen as it almost looks like brass on the outside and the stub appears to be brazed on. juts want to make sure it will hold up for LSH/p/spec and not fall apart and loose a prop
    Size is .150.
    Jim
    Billy Graham
  • longballlumber
    • 3132
    Sure sounds like a Hughey shaft to me, but there is no "real" way to find out who made it unless the seller knows...
    • sailr
      • Nov 2007
      • 6927
      Yep, most likely a Hughey shaft. I've started going to .187 shafts in everything. For some reason the .150's are not holding up for me in my spec boats.
      Mini Cat Racing USA
      www.minicatracingusa.com
      • JimClark
        • 5907
        Thanks for the info was just hoping it wasn't a Chinese one for sure.
        Jim
        Billy Graham
        • longballlumber
          • 3132
          Jim,
          I just remembered... I have a couple of pictures of a Hughey brand shaft in one of my threads. Take a look on post #4 and see if that helps you out...
          http://forums.offshoreelectrics.com/...n-my-Crew-Hull
          • JimClark
            • 5907
            Thanks yup that is what it looks like does he braze them on?
            Billy Graham
            • longballlumber
              • 3132
              Yes, he does as far as I know.
              Have fun
              Mike
                • 8011
                Ed once told me that the 1/8" cables were often stronger than the 0.150 flex stock he has often received. Bigger isn't always better.
                • Jeff Wohlt
                  • Jan 2008
                  • 2716
                  Depends where you got it it could be mine but a pic would show the real proof. I thought Eds shafts are different and generally have a drive dog on it and pinned.
                  www.rcraceboat.com
                  jwohlt5362@yahoo.com
                  • longballlumber
                    • 3132
                    I can't be 100% certian, but I think the .130 flex with 1/8" stubs have a pinned drive dog The larger sizes do not.
                    • JimClark
                      • 5907
                      Ok I put it on my flatbed scanner and scanned it
                      Billy Graham
                      • siberianhusky
                        • Dec 2009
                        • 2187
                        Between a Hyperformance, OSE, Octura, Aquacraft and Hughey I have on hand it looks like the Hughey
