Thrust Bearing Question
  • domwilson
    Moderator
    • 4405
    What are you guys using to lube the thrust bearing? I'm talking about the one that you mount on the motor shaft between the housing and coupler.
    Government Moto:
    • 7990
    I use marine R/C bearing oil from Boca Bearings - because I have it. Any high quality oil like Marvel Mystery Oil will work well. 3-in-1 is not a high quality oil IMO.
    • domwilson
      Moderator
      • 4405
      Do you think a good quality grease will work?
      Government Moto:
      • Eodman
        • Sep 2007
        • 1253
        What about powdered graphite, like we used on the axles of my sons derby racers in cub scouts?
        We did it with a Bang!
        Cats Are Where It's At!
        • ReddyWatts
          • 1700
          I am using "Purple Extreme" synthetic lubricant on all of the drive parts.
          Runs Clean – Doesn't Attract Dirt
          Originally Designed To Run Chains In Salt Water – Will Not Wash Off In Rain, Mud Or Snow
          All Conditions Lubrication Security – Protects From Wear Up To 400° F. and Down To -100° F.
          Does Not Harden in Cold Conditions
          Ultra High Film Strength – Prevents Metal To Metal Wear
          Stays In Place – Does Not Shed or Fling Off
          Helps Prevent Corrosion – Stops Rust
          ReddyWatts fleet photo
          • domwilson
            Moderator
            • 4405
            Sounds good. Where do we get something like that? Does it work on flex shafts?
            Government Moto:
            • ReddyWatts
              • 1700
              I found it at a bike show. It was engineered for lubricating metal in salt water applications. Like it better than the grease I was using. Tried it in boats running over 30,000 rpm with no problems. Use a light coating on the flex shaft and bearings. I left the flex in for a week after a run before I pulled it, no rust was found on the flex cable. Wiped the moisture/purple residue off and it was shiny.
              We have a big bike race here annualy. They usually give away free samples. I loaded up on it.
              http://search.stores.ebay.com/CS-Wes...870988QQsofpZ0.
