What are you guys using to lube the thrust bearing? I'm talking about the one that you mount on the motor shaft between the housing and coupler.
Thrust Bearing Question
I am using "Purple Extreme" synthetic lubricant on all of the drive parts.
Runs Clean – Doesn't Attract Dirt
Originally Designed To Run Chains In Salt Water – Will Not Wash Off In Rain, Mud Or Snow
All Conditions Lubrication Security – Protects From Wear Up To 400° F. and Down To -100° F.
Does Not Harden in Cold Conditions
Ultra High Film Strength – Prevents Metal To Metal Wear
Stays In Place – Does Not Shed or Fling Off
Helps Prevent Corrosion – Stops RustReddyWatts fleet photo
Mean Machine - Feigao 540 14XL, 8s, 100 amp HV esc, X537/3Comment
I found it at a bike show. It was engineered for lubricating metal in salt water applications. Like it better than the grease I was using. Tried it in boats running over 30,000 rpm with no problems. Use a light coating on the flex shaft and bearings. I left the flex in for a week after a run before I pulled it, no rust was found on the flex cable. Wiped the moisture/purple residue off and it was shiny.
We have a big bike race here annualy. They usually give away free samples. I loaded up on it.
http://search.stores.ebay.com/CS-Wes...870988QQsofpZ0.Last edited by ReddyWatts; 01-28-2008, 09:37 PM.ReddyWatts fleet photo
