Try some denatured alcohol if you have some this will let you know if there is any ink on the surface.
If the ink has seaped I would think this would remove it without having to wet sand.
If the alcohol shows signs of ink and doesn't remove it all the way try a clay bar I would think this would finish the job.
The sun trick should help some as with any decal when out in the sun the areas covered by the decals will be brighter then the rest if ever removed but yours looks a bit different because they were clear decals they did not completely cover the boats surface and sun light could deal through in the lighter printed areas. So the sunlight was not evenly distributed.
