Please Help me!!!!!
  • HYDROJERRY
    • Jan 2010
    • 2503
    Please Help me!!!!!
    I removed my decal cuz i run in pond water and the clear of the decal was turning tanish,, now after removing the decal it left the tan picture still on the hull,,,,i tryed rubbing alcohol and nothing so then i tryed a magic eraser and nothing!!!!!!!any ideals on how to get it off without hurting the paint?????
  • Rumdog
    • 6453
    I like the ghost lizard. Try a rubbing compound.
    • HYDROJERRY
      • Jan 2010
      • 2503
      i was thinking of that but wont the waxy leftover mess it up if i want to install other decals or clear coat it,, was hoping for some type of cleaner to just rub it off...
      • HyperJack
        • Nov 2010
        • 7
        Try with WD-40
        • Flying Scotsman
          Fast Electric Adict!
          • Jun 2007
          • 5190
          What is the original finish....paint, gelcoat,etc.??
          Douggie
          • Smoothops
            It is never fast enough..
            • 128
            Wet sand it and buff it.....
            • HYDROJERRY
              • Jan 2010
              • 2503
              Hyperjack,,,, what would wd-40 do i no it will take off the glue but this looks like its stained or something..
              Flying Scotsman,,, it is the factory paint ,,gelcoat i think..
              Smoothops,,, i thought of that but i used to detail cars years ago and no that after buffing in time some of the wetsanding will come back buffing or polishing mostly just fills in the scuffing and after time will show back up if you dont keep it waxed,,
              i think tonight ill try some one step cleaner wax or some super light compound,,all good ideas thow,, thanks for trying to help guys!!!
              • jamespl
                • 742
                if its clearcoat you could try a bar of detailing clay. i had some bird mess on my car and could not get the stain it left off with polish or wax, the clay got it off. takes some elbow grease tough.
                • Stinger9D9
                  • Jun 2007
                  • 355
                  It looks like the sun has faded the finish in the areas not protected by the decal. In other words, your hull has a "tan".
                  You'll most likely need to use a rubbing compound to remove the faded layers of paint (or gelcoat) until you get down to a level not affected by the sun - if you can. Sort of like using a cheese grater to scrape off a sunburn (ouch). You're probably better putting another decal on or repainting the boat if that fading goes too deep into the finish.
                  How long did you leave the boat out in the sun for this kind of damage to occur?
                  • graill
                    Retired
                    • 389
                    My dollar and two cents, your decals screwed you. The color leeching happens with decal/wrap brands that are not ink inert, chemicals in the ink stay active. Acids/carriers in the ink leech through and discolor the surface paint, clear or otherwise.
                    Its a simple reaction, like clear covers for example used to protect baseball cards or other documents causing the things they were supposed to protect to fade or yellow because of the chemicals in the protecting sleeve were still active.
                    Got a lot of sanding to do as others have pointed out. in the future ask the manufacturer of your decals/vinyl if the ink is "inert" meaning that the ink chemicaly locks once printed and does not bleed to other surfaces. Your 113 decal will likely show the same discoloration on the paint surface.
                    Observations by other members about sun damage is also valid but not the case here. On a side note to prevent sun damage use a good uv wax and reapply from time to time after stripping the old application away with iso alchohol. UV spec'd wax helps prevent the sun shadow situations due to fading of the paint and areas protected/covered by decals/vinyl.
                    • HYDROJERRY
                      • Jan 2010
                      • 2503
                      Well first im going to try everything before i start wetsanding,,,i realy hope its not color leeching,, ive only had the boat about two weeks and its only been out in the sun for about 4hrs per weekend,,, well im gonna try some things!!!!
                      • HYDROJERRY
                        • Jan 2010
                        • 2503
                        i tryed the one step cleaner wax last night nothing happend, i gess ill try something else...
                        • airman66285
                          • Aug 2009
                          • 244
                          I had the same problem as you did. What worked for me was leaving the hull out in direct sunlight for a couple of days. The UV evened everything out perfectly.
                          • coolmind
                            • Oct 2010
                            • 46
                            I have the same problem with a miss elam 1/12 and i will give a try to your idea.Thanks
                            • HYDROJERRY
                              • Jan 2010
                              • 2503
                              yep i had an elam and it had the same issue but i wasent replacing the decals so no prob, so ill give it a try,,seams if the sun caused it then hopefully it will fix it!!! Good idea Airman,,,
                              Nice boat avatar you got there coolmind,, i saw the pics in the pic section,,youd like my 32'' deepv,,ill have to post some pics un the pictures section..
